Home » Archived » BIRT » how to delete temprory file when report is finished created (Is It Possible to do this?)
how to delete temprory file when report is finished created (Is It Possible to do this?) [message #718343] Tue, 23 August 2011 23:36 Go to next message
i have a web application. with that web application i call BIRT Report which BIRT in running under tomcat server. i found that Viewer create temporary report in
"TomcatInstall\webapps\BIRT-Viewer\documents\".
How do i delete this temporary file when report is finished created so i won't make the space in the harddisk full?
i already use parameter __clean and __overwrite, but nothing is changed.
the url "http://localhost:8080/birt-viewer/frameset?__report=test.rptdesign&__clean=true" or
"http://localhost:8080/birt-viewer/frameset?__report=test.rptdesign&__overwrite=true"
I use :
- Eclipse Helios 2.6.1 (i made BIRT report in here)
- Tomcat 6
- BIRT Runtime 3.7
[Updated on: Wed, 24 August 2011 23:02] by Moderator
Re: how to delete temprory file when report is finished created [message #719254 is a reply to message #718343] Fri, 26 August 2011 10:04 Go to previous messageGo to next message
This should happen automatically when the session expires or the viewer
is restarted.
Jason
> temporary report in "TomcatInstall\webapps\BIRT-Viewer\documents\".
> I use :
> - Tomcat 6
> - BIRT Runtime 3.7
> Thanks
Re: how to delete temprory file when report is finished created [message #719831 is a reply to message #719254] Mon, 29 August 2011 03:10 Go to previous messageGo to next message
we created a java timer task to do this. You can configure the time
Re: how to delete temprory file when report is finished created [message #722192 is a reply to message #719831] Sun, 04 September 2011 22:18 Go to previous messageGo to next message
Hi Sam,
can u tell me how to create java timer task?
i googling, and have example like below :
import java.awt.Toolkit;
import java.util.Timer;
import java.util.TimerTask;
public class ReminderBeep {
Toolkit toolkit;
Timer timer;
public ReminderBeep(int seconds) {
toolkit = Toolkit.getDefaultToolkit();
timer = new Timer();
timer.schedule(new RemindTask(), seconds * 1000);
class RemindTask extends TimerTask {
public void run() {
System.out.println("Time's up!");
toolkit.beep();
//timer.cancel(); //Not necessary because we call System.exit
System.exit(0); //Stops the AWT thread (and everything else)
public static void main(String args[]) {
System.out.println("About to schedule task.");
new ReminderBeep(5);
System.out.println("Task scheduled.");
is the example above is java timer?
sorry, i'm new in java
sam wrote on Mon, 29 August 2011 03:10
Re: how to delete temprory file when report is finished created [message #722201 is a reply to message #722192] Sun, 04 September 2011 23:43 Go to previous message
Replace the following code
toolkit.beep();
//timer.cancel();
System.exit(0);
with your code. Your code needs to scan thru the temporary directory (where the documents are created - Web Viewer setting) and delete them.
Previous Topic:IReportContext
Next Topic:PieChart: All zero/null values
Current Time: Sun Jul 27 08:07:15 EDT 2025
Powered by FUDForum. Page generated in 0.04187 seconds
