An error occurred while automatically activating bundle org.eclipse.ajdt.ui [message #71810] |
Fri, 13 June 2008 15:26  |
I am new to this ajdt.
I installed apache derby this morning and also ran some junit test on an
already existing projects in my workspace which were running smoothly till
this morning.
Update Manager had downloaded and installed some updates for the
AJDT.After that my workspace seems to be unstable and I cant make the
Derby Network Manager run or any junit tests.
I get the following error message when I run the junit tests.
Plug-in org.eclipse.ajdt.ui was unable to load class
org.eclipse.ajdt.internal.ui.ajde.CachedRuntimeClasspathEntr yResolver.
org.eclipse.ajdt.ui (81).
when I tried running the derby Network Server this is what I got
Error starting Derby Network Server:
Plugin-in org.eclipse.ajdt.ui was unable to load class
Also my eclipse workspace has been giving an error about the workspace
being already in use when ever I start it.
Is there a fix for this or do I revert back to the workspace before the
AJDT update.
If so How can I do it?
Thnx for the help.
FUDForum. Page generated in 0.03473 seconds
