Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » teneo and ID
teneo and ID [message #71715] Thu, 15 February 2007 05:20 Go to next message
Originally posted by: pascalpugatsch.hotmail.com
relating to the annotations of my model I'd like to ask if there's a way
to specify a "@GeneratedValue" of GUID as id type?
Pascal
Re: teneo and ID [message #71734 is a reply to message #71715] Thu, 15 February 2007 07:04 Go to previous messageGo to next message
Hi Pascal,
You can try the following. First set this annotation (at epackage level or at the id eattribute):
@GenericGenerator(name="system-guid", strategy = "guid")
and then for the id eattribute set:
@GeneratedValue(generator="system-guid")
gr. Martin
Pascal Pugatsch wrote:
> Pascal
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: teneo and ID [message #71770 is a reply to message #71734] Thu, 15 February 2007 10:43 Go to previous messageGo to next message
Hi Martin,
still not working.
when I have the annotations for my model:
@model unique="true" unsettable="true"
dataType="org.eclipse.emf.ecore.xml.type.String" required="false"
* annotation="teneo.jpa
appinfo='\n\t\t\t\t@Id\n\t\t\t\t@GenericGenerator(name=\"system-guid\",
strategy = \"guid\")\n\t\t\t'"
appinfo='\n\t\t\t\t@Id\n\t\t\t\t@GeneratedValue(generator=\"system-guid\")\n\t\t\t'"
* extendedMetaData="kind='element' name='id'"
I get:
2007-02-15 16:37:30,503 ERROR [-main] parser.AnnotationParserException
- The eclass: HbAnnotatedEAttribute does not have an efeature for
GenericGenerator
org.eclipse.emf.teneo.annotations.parser.AnnotationParserExc eption: The
GenericGenerator
cheers,
Pascal
Re: teneo and ID [message #71789 is a reply to message #71770] Thu, 15 February 2007 10:47 Go to previous messageGo to next message
Hi Pascal,
Which version of Teneo are you working with? In a newer release (like 2 weeks old) this should work.
If you have an older release then the GenericGenerator annotation should be set on the epackage and
the GeneratedValue on the eattribute.
gr. Martin
> Hi Martin,
> still not working.
> I get:
> parser.AnnotationParserException - The eclass: HbAnnotatedEAttribute
> does not have an efeature for GenericGenerator
> GenericGenerator
> cheers,
> Pascal
The Netherlands
Re: teneo and ID [message #71808 is a reply to message #71789] Thu, 15 February 2007 12:02 Go to previous message
Thanks Martin!
I used an older version and updated now to Teneo 0.8.0.
When I set the GenericGenerator on EPackage level it works perfect!
cheers, Pascal
Re: teneo and ID [message #602603 is a reply to message #71715] Thu, 15 February 2007 07:04 Go to previous message
Hi Pascal,
gr. Martin
> Pascal
The Netherlands
Re: teneo and ID [message #602617 is a reply to message #71734] Thu, 15 February 2007 10:43 Go to previous message
Hi Martin,
still not working.
I get:
GenericGenerator
GenericGenerator
cheers,
Pascal
Re: teneo and ID [message #602620 is a reply to message #71770] Thu, 15 February 2007 10:47 Go to previous message
Hi Pascal,
gr. Martin
> Hi Martin,
> still not working.
> I get:
> GenericGenerator
> cheers,
> Pascal
The Netherlands
Re: teneo and ID [message #602624 is a reply to message #71789] Thu, 15 February 2007 12:02 Go to previous message
Thanks Martin!
cheers, Pascal
Previous Topic:teneo and ID
Next Topic:Why is the unique attribute of EAttribute ignored?
Current Time: Sat Jul 26 13:22:28 EDT 2025
Powered by FUDForum. Page generated in 0.04453 seconds
