Home » Modeling » TMF (Xtext) » While ,Run As -> Generate Xtext Artifacts( why does it connect to word wide web for code generation?)
While ,Run As -> Generate Xtext Artifacts [message #717728] Mon, 22 August 2011 03:48 Go to next message
While we are generating code by right click Run As-- Generate Xtext Artifacts
why does it connect to word wide web?
Re: While ,Run As -> Generate Xtext Artifacts [message #717747 is a reply to message #717728] Mon, 22 August 2011 04:43 Go to previous messageGo to next message
maybe it trys to download antlr (parser generator not runtime) if you haven't installed it.
~Christian
Re: While ,Run As -> Generate Xtext Artifacts [message #717780 is a reply to message #717747] Mon, 22 August 2011 06:40 Go to previous messageGo to next message
Hi Christian
I installed Xtext 2.0 SDK , doesnt it contains the antlr?
/caner
Re: While ,Run As -> Generate Xtext Artifacts [message #717782 is a reply to message #717780] Mon, 22 August 2011 06:54 Go to previous message
No,
cause of ip issue you have to install it separately.
~Christian
Previous Topic:Getting StructuralFeatures even from superclass?
Next Topic:[xtend] Ecore post processing
Current Time: Sun Jul 20 21:09:54 EDT 2025
Powered by FUDForum. Page generated in 0.06693 seconds
