Home » Archived » Maven Integration (M2E) » No aspectj-maven-plugin m2e connector
No aspectj-maven-plugin m2e connector [message #717722] Mon, 22 August 2011 03:38 Go to next message
In Eclipse with m2eclipcse 1.0.100 I have the following error:
Plugin execution not covered by lifecycle configuration: org.codehaus.mojo:aspectj-maven-plugin:1.3.1:compile (execution: default, phase: compile)
When I click "Discover new m2e connectors" nothing is found.
Is there any connector available for org.codehaus.mojo:aspectj-maven-plugin?
If no, do you know if someone is going to write it?
Is there any FAQ for writing m2e connectors?
Re: No aspectj-maven-plugin m2e connector [message #734304 is a reply to message #717722] Fri, 07 October 2011 08:12 Go to previous message
Try with plugin found at following repo:
http://dist.springsource.org/release/AJDT/configurator
[Updated on: Fri, 07 October 2011 08:12] by Moderator
Previous Topic:File is out of sync problem
Next Topic:What Does Build Automatically Do?
Current Time: Wed Jul 23 07:36:18 EDT 2025
Powered by FUDForum. Page generated in 0.25381 seconds
