Home » Archived » BIRT » localization file(link dinamically a resource file)
localization file [message #710234] Thu, 04 August 2011 16:58 Go to next message
Hi all
Is there anyway to assign a resource key to a text label dynamically?
Do i need to use a kind of scripting for each label that I need to translate base on the locale of the machine?
Thanks for any input.
Re: localization file [message #710267 is a reply to message #710234] Thu, 04 August 2011 17:25 Go to previous messageGo to next message
Take a look at this example
http://www.birt-exchange.org/org/devshare/designing-birt-reports/351-localization-of-birt-reports/
You also may want to look at this wiki page:
http://www.birt-exchange.org/org/wiki/index.php?title=BIRT:Internationalization
Jason
On 8/4/2011 4:58 PM, JulioC wrote:
> Hi all
> Is there anyway to assign a resource key to a text label dynamically? Do
Re: localization file [message #715220 is a reply to message #710267] Fri, 12 August 2011 15:44 Go to previous messageGo to next message
Thanks Jason
It worked as expected
One more question
It is possible to insert an image dynamically?
We have a report that the only thing changes is the customer, we want to insert dynamically its logo on it.
Re: localization file [message #715249 is a reply to message #715220] Fri, 12 August 2011 18:08 Go to previous messageGo to next message
Take a look at this post:
http://birtworld.blogspot.com/2010/09/birt-image-report-item.html
Jason
On 8/12/2011 3:44 PM, JulioC wrote:
> Thanks Jason
> One more question
> Thanks
Re: localization file [message #717267 is a reply to message #715249] Fri, 19 August 2011 15:11 Go to previous messageGo to next message
Hi Jason Thanks for the link
I was able to do it as this :
1 . this.URI = "file:///C:/eclipsework/myreports/myimage.png";
That was on a windows box, however I couldn't get it working on a linux box, is there any syntax rule for Linux? I tried
this.URI = "report/images/myimage.png" and it does not work (we have birt runtime on a tomcat servlet)
I tried
2. this.URI="http://myhost/report/images/myimage.png" and it worked as expected
We prefer the number 1 idea, it is more flexible when you have the same report for several clients with a different logo, so you can have symlink to myimage.png
Idea number 2 will be great if BIRT can retrieve the hostname of the box so we could have something like this
this.URI="http://${hostname}/report/images/myimage.png"
We want to have only one report design for several clients where the hostname is different.
Thanks in advance for any idea for this.
JulioC.
[Updated on: Fri, 19 August 2011 15:13] by Moderator
Re: localization file [message #717284 is a reply to message #717267] Fri, 19 August 2011 16:18 Go to previous messageGo to next message
Can you try a linux uri like:
http://en.wikipedia.org/wiki/File_URI_scheme
Jason
> 1 . this.URI = "file:///C:/eclipsework/myreports/myimage.png"; That was
> there any syntax rule for Linux? I tried this.URI =
> I tried 2. this.URI="http://myhost/report/images/myimage.png" and it
> worked as expected
> JulioC.
Re: localization file [message #717299 is a reply to message #717284] Fri, 19 August 2011 17:09 Go to previous messageGo to next message
Hi Jason
Thanks a lot
That did the trick.
Re: localization file [message #718212 is a reply to message #717299] Tue, 23 August 2011 11:51 Go to previous messageGo to next message
Hi Jason
I got the report working using birt viewer on tomcat.
However I have a question, it is possible using javascript to guess the OS of the browser in BIRT?
I was trying to use a normal javascript tool
navigator.appVersion.indexOf("Win")
is there any similar way to do that in BIRT?
Re: localization file [message #718225 is a reply to message #718212] Tue, 23 August 2011 12:14 Go to previous messageGo to next message
You can do this with client side script. Just add a text element to the
report, set its type to html and enter this code:
<script language="JavaScript">
alert( navigator.appVersion );
</script>
Jason
On 8/23/2011 11:51 AM, JulioC wrote:
> Hi Jason
> Thanks
Re: localization file [message #718226 is a reply to message #718225] Tue, 23 August 2011 12:19 Go to previous message
You can always get the user agent header from the request before the
report runs as well:
brw = reportContext.getHttpServletRequest().getHeader("User-Agent");
Jason
> </script>
> Jason
>> Hi Jason
>> Thanks
Previous Topic:Empty data set?
Next Topic:Specifying a path to a Log Directory at run time; Report Viewer App
Current Time: Sat Jul 26 23:36:05 EDT 2025
Powered by FUDForum. Page generated in 0.04885 seconds
