Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Splash/Shell resize problems on Linux (Ubuntu 10.04)(Having difficulty shrinking the splash screen)
Splash/Shell resize problems on Linux (Ubuntu 10.04) [message #716834] Thu, 18 August 2011 10:41 Go to next message
I've implemented an extension to the BasicSplashHandler, although this really has to do with the Shell class. I take the Shell, get its original bounds, add some controls to it, and get the user's login information. Once I have the user's info, I want to restore the Shell to its original size. Here's what I'm doing to restore the Shell:
    void restoreSplashScreen(Shell splash, Rectangle bounds) {
        // don't show while we rearrange things
        splash.setVisible(false);
        // now discard our controls and restore the original splash screen
        for (Control control : splash.getChildren()) {
            control.dispose();
        // restore the splash screen size/location
        splash.setBounds(bounds);
        // Now show it
        splash.layout();
        splash.setVisible(true);
On Windows, the Shell returns to normal. On Linux, the Shell stays at its larger size.
I've tried setLocation() and setSize(), pack(), redraw(), and update()... but I can't get this window to return to its original size.
FWIW: the RESIZE style is not set (is there a way to set this after the window is created?), and there is no Layout nor LayoutData associated with the Shell (layout is null).
Can anyone help with this?
Thanks!
-- Steve G.
Re: Splash/Shell resize problems on Linux (Ubuntu 10.04) [message #716894 is a reply to message #716834] Thu, 18 August 2011 13:41 Go to previous messageGo to next message
What layout manager you are using? IMHO setting the bounds is useless if you invoke layout immediately later.
Re: Splash/Shell resize problems on Linux (Ubuntu 10.04) [message #717027 is a reply to message #716894] Fri, 19 August 2011 01:41 Go to previous messageGo to next message
Yes i also agree on this,but if there is no layout management ,then how were you managing the controls which u disposed in your code.
either way layout and bounds are not related unless there is a parent with a layout.(correct me if i am wrong)
try by only setting bounds.
Re: Splash/Shell resize problems on Linux (Ubuntu 10.04) [message #718493 is a reply to message #716834] Wed, 24 August 2011 09:54 Go to previous messageGo to next message
The lines you've posted seem fine, splash.setBounds() should be all you
need to do since splash doesn't have a Layout set on it. The Shell does
not need the SWT.RESIZE creation style in order for you to change its
bounds, this bit just controls whether resize handles should be
available to the user for dragging.
Is it possible that the setBounds() is succeeding but the size is then
being influenced some time later in your code? After invoking
setBounds() what does getBounds() answer? Does this answer change
later? If none of this sheds any light on what's happening then you
could be seeing a bug, especially since this works on win32 for you. If
you think this is the case then you should log a bug with SWT at
https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Platform&component=SWT
for further investigation.
Grant
> control.dispose();
> // Now show it
> splash.layout();
> its larger size.
> Thanks!
> -- Steve G.
Re: Splash/Shell resize problems on Linux (Ubuntu 10.04) [message #718511 is a reply to message #718493] Wed, 24 August 2011 11:05 Go to previous message
I tried a few things. Obviously, I'm not an expert in SWT. The attempt at calling layout() (even though the object's Layout and LayoutData are both null) was just a shot in the dark.
During some debugging, I manually set the style bit, and the splash worked. I'm now using reflection to set it, and it works in some cases.
Hmm... as for setBounds()... I was doing a setBounds() call using the original splash screen size every time getSplash() or getContent() was being called, but the window would never shrink/change size.
I've added listeners for every SWT event (even paint and mouse events), but I don't see anything that stands out as patently wrong. Are there some debug settings in SWT which I could enable to get more information?
Previous Topic:dynamic combo generation
Next Topic:SWT Text spell checker
Current Time: Fri Jul 25 22:57:27 EDT 2025
Powered by FUDForum. Page generated in 0.04486 seconds
