PDT/Xdebug strange behavior - can't resolve it [message #71658] |
Thu, 22 May 2008 22:04  |
Originally posted by: alan.catterson.comcast.net
Hello. I've been trying to resolve this for 2 days. Decided I need some help
O/S: XP
PHP: 5.2.6
Debug Build => no
Thread Safety => Enabled
Apache: 2.0.58
Xdebug: 2.0.3
Eclipse: 3.3.0
Build id => I20070625-1500
Eclipse PDT: 1.0.2
PHP.INI excerpt:
[Xdebug]
xdebug.remote_enable=1
xdebug.remote_host="localhost"
xdebug.remote_port=9000
xdebug.remote_handler="dbgp"
xdebug.remote_log="C:\Program Files\Apache Group\Apache2\logs\Xdebug.log"
zend_extension_ts=C:\php\ext\php_xdebug-2.0.3-5.2.5.dll"
PROBLEM:
I have a very small PHP app that I'm using to learn PHP. The 2 files are
shown below:
new_player_start_form.html:
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=ISO-8859-1">
<title>Player Entry Form</title>
</head>
<body>
<form id="entry" action="new_player.php"
method="POST">
<p><strong>First Name: </strong> <input type="text" name="firstName" /></p>
<p><strong>Last Name: </strong> <input type="text" name="lastName" /></p>
<input type="submit" value="Save" /></form>
</body>
</html>
new_player.php:
<?php
if (isset($_POST["firstName"])&& isset($_POST["lastName"])) {
require_once(dirname(__FILE__)."/db.php");
$firstName = mysqli_escape_string($conn, $_POST["firstName"]);
$lastName = mysqli_escape_string($conn, $_POST["lastName"]);
$fullName = "$firstName $lastName";
$sql = "insert into Players(First_Name, Last_Name) values
('$firstName','$lastName')";
mysqli_query($conn, $sql);
$id = mysqli_insert_id($conn);
echo "Insert successful for $fullName new ID=$id";
} else {
echo "Please fill in both First and Last names";
In eclipse PHP perspective:
-Right click on new_player_start_form.html =>Debug As=>Open Debug Dialog
Debug Dialog Info:
Server debugger: Xdebug
PHP Server: Default PHP Web Server
-Click "Debug"
Here's where it gets strange:
- External browser (IE7) pops up (same thing happens w/ eclipse internal
browser)
- Web page "connecting ..."
- URL:
http://localhost/new_player_start_form.html?XDEBUG_SESSION_S TART=ECLIPSE_DBGP&KEY=12115074127964
- It just hangs there ... forever
- PHP Debug perspective:
- Right Click on "Remote Launch"
- Select "Terminate All"
- After a few seconds, the HTML form I was expecting shows up in browser
- THEN ... 2 MORE external IE7 browsers open
- Both browsers display "DEBUG SESSION ENDED"
- URLs in both browsers are the same (shown below)
XDEBUG_SESSION_STOP_NO_EXEC=ECLIPSE_DBGP&KEY=12115074127 964
http://localhost/new_player_start_form.html?XDEBUG_SESSION_S TOP_NO_EXEC=ECLIPSE_DBGP&KEY=12115074127964
Xdebug Log File:
Log opened at 2008-05-23 01:50:40
-> <init xmlns="urn:debugger_protocol_v1"
xmlns:xdebug="http://xdebug.org/dbgp/xdebug"
fileuri="file:///C:/workspace/learn/new_player_start_form.html"
language="PHP" protocol_version="1.0" appid="3820"
idekey="ECLIPSE_DBGP"><engine
version="2.0.3"><![CDATA[Xdebug]]></engine><author><![CDATA[Derick
Rethans]]></author><url><![CDATA[http://xdebug.org]]></url><copyright><![CDATA[Copyright
(c) 2002-2008 by Derick Rethans]]></copyright></init>
<- feature_set -i 22 -n show_hidden -v 1
-> <response xmlns="urn:debugger_protocol_v1"
xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="feature_set"
transaction_id="22" feature="show_hidden" success="1"></response>
<- feature_set -i 23 -n max_depth -v 3
transaction_id="23" feature="max_depth" success="1"></response>
<- feature_get -i 24 -n max_children
xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="feature_get"
transaction_id="24" feature_name="max_children"
supported="1"><![CDATA[32]]></response>
<- feature_get -i 25 -n encoding
transaction_id="25" feature_name="encoding"
supported="1"><![CDATA[iso-8859-1]]></response>
<- feature_get -i 26 -n supports_async
transaction_id="26" feature_name="supports_async"
supported="1"><![CDATA[0]]></response>
<- breakpoint_set -i 27 -t line -f
file:///C:%5Cworkspace%5Clearn%5Cnew_player.php -n 4
xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="breakpoint_set"
transaction_id="27" id="38200001"></response>
<- run -i 28
xmlns:xdebug="http://xdebug.org/dbgp/xdebug" command="run"
transaction_id="28" status="stopping" reason="ok"></response>
Log closed at 2008-05-23 01:53:30
So ... I've googled for 2 days, and I have only found 1 "kind of" reference
to the problem. It suggested upgrading to latest PDT. Did it. Same behavior.
If anyone has any info that could help me here ... I'd greatly appreciate
it. If its something stupid in the PHP/HTML code ... note that I'm a
beginner :-) Nevertheless ... its a dinky app that works fine outside the
debugger.
Alan
FUDForum. Page generated in 0.03113 seconds
