Home » Archived » BIRT » Table headers/footers on each page
Table headers/footers on each page [message #716560] Wed, 17 August 2011 13:11 Go to next message
Is there any way we can show table header / footer on each page. I searched the forums, and saw that we can achieve this by row count grouping. But for me the issue is, I do not know how many rows each page can take... b'cos the row data size can vary (dynamic text control). Is there any other way we can achieve this. just want to know if there is any update after the last post on this. We are using BIRT 2.6.2
Re: Table headers/footers on each page [message #716609 is a reply to message #716560] Wed, 17 August 2011 16:35 Go to previous messageGo to next message
Sam,
You should be able to use repeat header checkbox on the table page break
properties. For the footer you will most likely have to use the master
page footer and page variables.
Jason
> Thanks
Re: Table headers/footers on each page [message #721629 is a reply to message #716609] Fri, 02 September 2011 07:07 Go to previous messageGo to next message
I know it (repeating table footer in each page - like the header checkbox without any coding) is not possible in 2.6.2. Is it possible in 3.7?
[Updated on: Fri, 02 September 2011 07:08] by Moderator
Re: Table headers/footers on each page [message #721692 is a reply to message #721629] Fri, 02 September 2011 11:13 Go to previous messageGo to next message
That is currently implemented in 3.7.
Jason
> 3.7?
> Thanks
> Swamy
Re: Table headers/footers on each page [message #721720 is a reply to message #721692] Fri, 02 September 2011 12:44 Go to previous messageGo to next message
For table header there is a property "Repeat Header". But I dont see an equivalent property for footer.
I tried using "Repeatable" property on the footer row, but no luck. (Working in 3.7)
[Updated on: Fri, 02 September 2011 12:44] by Moderator
Re: Table headers/footers on each page [message #986435 is a reply to message #716560] Tue, 20 November 2012 07:17 Go to previous message
Change the SQL statement to and get the row_number() and group on that.
Previous Topic:Child data set table name needs seeded on Parent table column value
Next Topic:Dynamic chart
Current Time: Thu Jul 24 22:55:58 EDT 2025
Powered by FUDForum. Page generated in 0.13395 seconds
