Home » Archived » BIRT » Sub Reports on Scripted datasets
Sub Reports on Scripted datasets [message #716001] |
Tue, 16 August 2011 03:53  |
Hi All,
I have read other other posts on this subject but cannot make sense of the answers (new to more complex birt reports). I have a main dataset (WODETAIL) and for each row I need display a list of WOSTATUS in a nested table/subreport. For this report I need to use scripted datasets. Please can anyone shed light on how I need to adapt the code below?
Main Data Set - WODETAIL:
OPEN:
maximoDataSet = MXReportDataSetProvider.create(this.getDataSource().getName(), this.getName());
maximoDataSet.open();
var sqlText = new String();
// Add query to sqlText variable.
sqlText = " select WONUM, "
+ " WORKORDER.DESCRIPTION, "
+ " MULTIASSETLOCCI.FEATURE, "
+ " MULTIASSETLOCCI.featurelabel, "
+ " WORKORDER.M_CUSTOMERREF, "
+ " WORKORDER.PLUSPCUSTOMER, "
+ " PLUSPCUSTOMER.NAME, "
+ " WORKORDER.PARENT, "
//+ " PARENT_DESCRIPTON = case len(WORKORDER.PARENT) when 0 then '' else WO2.description END, "
+ " WORKORDER.LOCATION, "
+ " LOCATIONS.DESCRIPTION AS LOCATION_DESC, "
+ " WORKORDER.ASSETNUM, "
+ " ASSET.DESCRIPTION AS ASSET_DESC, "
+ " WORKORDER.PLUSPCITY, "
+ " ASSET.M_NORTHING1, "
+ " ASSET.M_NORTHING2, "
+ " ASSET.M_EASTING1, "
+ " ASSET.M_EASTING2, "
+ " WORKORDER.M_SUMMARY, "
+ " LONGDESCRIPTION.ldtext as LONGDESCRIPTION, "
+ " WORKORDER.WORKTYPE, "
+ " WORKTYPE.WTYPEDESC, "
+ " WORKORDER.M_FUNCTION, "
+ " M_FUNCTION.DESCRIPTION AS M_FUNCTION_DESC, "
+ " WORKORDER.M_ACTIVITY, "
+ " M_ACTIVITY.DESCRIPTION AS M_ACTIVITY_DESC, "
+ " WORKORDER.M_LENGTH, "
+ " WORKORDER.M_DEPTH, "
+ " WORKORDER.M_WIDTH, "
+ " WORKORDER.M_DIAMETER, "
+ " WORKORDER.M_XCOORDINATE, "
+ " WORKORDER.M_YCOORDINATE, "
+ " WORKORDER.SITEID, "
+ " WORKORDER.STATUS, "
+ " WORKORDER.STATUSDATE, "
+ " WORKORDER.REPORTDATE, "
+ " WORKORDER.M_WOPRIORITY, "
+ " M_WOPRIORITY.DESCRIPTION AS M_WOPRIORITY_DESC, "
+ " WORKORDER.TARGSTARTDATE, "
+ " WORKORDER.TARGCOMPDATE, "
+ " WORKORDER.SCHEDSTART, "
+ " WORKORDER.SCHEDFINISH, "
+ " WORKORDER.ACTSTART, "
+ " WORKORDER.ACTFINISH, "
+ " WORKORDER.M_SOURCE, "
+ " WORKORDER.ORIGRECORDCLASS+''+WORKORDER.ORIGRECORDID as SOURCE_RECORD, "
+ " WORKORDER.M_NOTICETYPE, "
+ " WORKORDER.M_NOTICEREQD, "
+ " WORKORDER.M_FIXEDDATE, "
+ " WORKORDER.M_FIXEDRESOURCE, "
+ " WORKORDER.JPNUM, "
+ " WORKORDER.PMNUM, "
+ " WORKORDER.CONTRACT, "
+ " WORKORDER.M_BUDGETCODE1, "
+ " WORKORDER.M_CONTYEAR, "
+ " WORKORDER.M_SIO, "
+ " WORKORDER.M_COSTHEAD "
+ " from workorder "
+ " left join ASSET on WORKORDER.ASSETNUM=ASSET.ASSETNUM "
+ " left join LOCATIONS on WORKORDER.LOCATION=LOCATIONS.LOCATION "
+ " LEFT JOIN MULTIASSETLOCCI ON WORKORDER.ASSETNUM = MULTIASSETLOCCI.ASSETNUM and WORKORDER.WONUM=MULTIASSETLOCCI.recordkey AND MULTIASSETLOCCI.recordclass = 'WORKORDER' "
+ " left join PLUSPCUSTOMER on WORKORDER.PLUSPCUSTOMER=PLUSPCUSTOMER.CUSTOMER "
+ " left join WORKTYPE on WORKORDER.WORKTYPE=WORKTYPE.WORKTYPE and worktype.orgid = 'HWYS' "
+ " left join longdescription on workorder.workorderid=longdescription.ldkey and longdescription.ldownertable = 'WORKORDER' and ldownercol = 'DESCRIPTION' "
+ " left join (select domainid, value, description from ALNDOMAIN where domainid = 'M_FUNCTION') M_FUNCTION on workorder.M_FUNCTION = M_FUNCTION.value "
+ " left join (select domainid, value, description from ALNDOMAIN where domainid = 'M_ACTIVITY') M_ACTIVITY on workorder.M_ACTIVITY = M_ACTIVITY.value "
+ " left join (select domainid, value, description from ALNDOMAIN where domainid = 'M_ACTIVITY') M_WOPRIORITY on workorder.M_WOPRIORITY = M_WOPRIORITY.value "
// Include the Maximo where clause
+ " where workorder.wonum is not null and workorder.wonum = '100198' "
//+ "and workorder.wonum='" + params["Work Order Number"] + "'"
//+ " and " + params["where"]
maximoDataSet.setQuery(sqlText);
FETCH
if (!maximoDataSet.fetch())
return (false);
// Add a line for each output column
// The specific get method should match the data type of the output column.
row["WONUM"] = maximoDataSet.getString("WONUM");
row["DESCRIPTION"] = maximoDataSet.getString("DESCRIPTION");
row["ASSETNUM"] = maximoDataSet.getString("ASSETNUM");
row["STATUS"] = maximoDataSet.getString("STATUS");
row["SITEID"] = maximoDataSet.getString("SITEID");
row["FEATURE"] = maximoDataSet.getString("FEATURE");
row["featurelabel"] = maximoDataSet.getString("featurelabel");
row["M_CUSTOMERREF"] = maximoDataSet.getString("M_CUSTOMERREF");
row["PLUSPCUSTOMER"] = maximoDataSet.getString("PLUSPCUSTOMER");
row["NAME"] = maximoDataSet.getString("NAME");
row["PARENT"] = maximoDataSet.getString("PARENT");
row["LOCATION"] = maximoDataSet.getString("LOCATION");
row["LOCATION_DESC"] = maximoDataSet.getString("LOCATION_DESC");
row["ASSET_DESC"] = maximoDataSet.getString("ASSET_DESC");
row["PLUSPCITY"] = maximoDataSet.getString("PLUSPCITY");
row["M_NORTHING1"] = maximoDataSet.getString("M_NORTHING1");
row["M_NORTHING2"] = maximoDataSet.getString("M_NORTHING2");
row["M_EASTING1"] = maximoDataSet.getString("M_EASTING1");
row["M_EASTING2"] = maximoDataSet.getString("M_EASTING2");
row["M_SUMMARY"] = maximoDataSet.getString("M_SUMMARY");
row["LONGDESCRIPTION"] = maximoDataSet.getString("LONGDESCRIPTION");
row["WORKTYPE"] = maximoDataSet.getString("WORKTYPE");
row["WTYPEDESC"] = maximoDataSet.getString("WTYPEDESC");
row["M_FUNCTION"] = maximoDataSet.getString("M_FUNCTION");
row["M_FUNCTION_DESC"] = maximoDataSet.getString("M_FUNCTION_DESC");
row["M_ACTIVITY"] = maximoDataSet.getString("M_ACTIVITY");
row["M_ACTIVITY_DESC"] = maximoDataSet.getString("M_ACTIVITY_DESC");
row["M_LENGTH"] = maximoDataSet.getString("M_LENGTH");
row["M_DEPTH"] = maximoDataSet.getString("M_DEPTH");
row["M_WIDTH"] = maximoDataSet.getString("M_WIDTH");
row["M_DIAMETER"] = maximoDataSet.getString("M_DIAMETER");
row["M_XCOORDINATE"] = maximoDataSet.getString("M_XCOORDINATE");
row["M_YCOORDINATE"] = maximoDataSet.getString("M_YCOORDINATE");
row["STATUSDATE"] = maximoDataSet.getString("STATUSDATE");
row["REPORTDATE"] = maximoDataSet.getString("REPORTDATE");
row["M_WOPRIORITY"] = maximoDataSet.getString("M_WOPRIORITY");
row["M_WOPRIORITY_DESC"] = maximoDataSet.getString("M_WOPRIORITY_DESC");
row["TARGSTARTDATE"] = maximoDataSet.getString("TARGSTARTDATE");
row["TARGCOMPDATE"] = maximoDataSet.getString("TARGCOMPDATE");
row["SCHEDSTART"] = maximoDataSet.getTimestamp("SCHEDSTART");
row["SCHEDFINISH"] = maximoDataSet.getTimestamp("SCHEDFINISH");
row["ACTSTART"] = maximoDataSet.getTimestamp("ACTSTART");
row["ACTFINISH"] = maximoDataSet.getTimestamp("ACTFINISH");
row["M_SOURCE"] = maximoDataSet.getString("M_SOURCE");
row["SOURCE_RECORD"] = maximoDataSet.getString("SOURCE_RECORD");
row["M_NOTICETYPE"] = maximoDataSet.getString("M_NOTICETYPE");
row["M_FIXEDRESOURCE"] = maximoDataSet.getString("M_FIXEDRESOURCE");
row["M_FIXEDDATE"] = maximoDataSet.getString("M_FIXEDDATE");
row["JPNUM"] = maximoDataSet.getString("JPNUM");
row["PMNUM"] = maximoDataSet.getString("PMNUM");
row["CONTRACT"] = maximoDataSet.getString("CONTRACT");
row["M_BUDGETCODE1"] = maximoDataSet.getString("M_BUDGETCODE1");
row["M_CONTYEAR"] = maximoDataSet.getString("M_CONTYEAR");
row["M_SIO"] = maximoDataSet.getString("M_SIO");
row["M_COSTHEAD"] = maximoDataSet.getString("M_COSTHEAD");
//row["datefield"] = maximoDataSet.getTimestamp("datefield");
return (true);
Sub report dataset
OPEN
+ " STATUS, "
+ " CHANGEDATE, "
+ " CHANGEBY "
+ " from wostatus "
//+ " where workorder.wonum is not null and workorder.wonum = '100012' "
//+ " where " + params["where"]
//+ " where wostatus.wonum ='" + params["param_1"] + "'"
// USING GUI I CREATED A PARAM CALL PARAM_1
+ " where wostatus.wonum ='"+params["PARAM_1"]+"'";
FETCH
return (false);
row["CHANGEDATE"] = maximoDataSet.getString("CHANGEDATE");
row["CHANGEBY"] = maximoDataSet.getString("CHANGEBY");
return (true);
Any and all suggestions on how to fix this would be very much appreciated.
Many Thanks,
Gavin
[Updated on: Tue, 16 August 2011 03:55] by Moderator
Re: Sub Reports on Scripted datasets [message #716234 is a reply to message #716001] |
Tue, 16 August 2011 14:00   |
In your nested dataset it looks like you are using a report parameter.
A better approach is to use a dataset parameter. Take a look at the
attached example. It has an outer and inner datset. The inner dataset
is bound to a nested table in the report. It also has an input
parameter for the dataset. If you select the nested table and then
click on the binding tab in the properties editor you will see a button
to set the dataset input pararmeter. In the example it is setting it to
a value from the outer table (in your case that would be row["WONUM"])
The nested script uses this input parameter in its open method to set a
starting variable.
Jason
On 8/16/2011 3:54 AM, gavinR wrote:
> Hi All,
> OPEN:
> FETCH
> return (false);
> return (true);
> Sub report dataset
> OPEN
> + " STATUS, "
> + " CHANGEDATE, "
> + " CHANGEBY "
> + " from wostatus "
> FETCH
> return (false);
> return (true);
Re: Sub Reports on Scripted datasets [message #1779018 is a reply to message #716695] |
Thu, 28 December 2017 13:47  |
In this report I want to get the work order and description in one line
and statuses and changedate reiterated for the othere workorders.
but i am getting only first workorder and its related statuses.
I need all the workorders in the same format.
Please help....
Current Time: Sat Jul 26 00:40:05 EDT 2025
Powered by FUDForum. Page generated in 0.03273 seconds
