| How can the 'ecf.exported.containerfactoryargs' set dynamically while using DS? [message #716175] |
Tue, 16 August 2011 11:38  |
what is the best practice to register a service declaratively while dynamically providing the IP address of the host computer?
I declared the following service:
<scr:component xmlns:scr="http://www.osgi.org/xmlns/scr/v1.1.0" name="remote.service.provider">
<implementation class="remote.service.provider.EchoService"/>
<service>
<provide interface="remote.service.IEchoService"/>
</service>
<property name="service.exported.interfaces" type="String" value="*"/>
<property name="service.exported.configs" type="String" value="ecf.r_osgi.peer"/>
<property name="ecf.exported.containerfactoryargs" type="String" value="r-osgi://1.2.3.4:9278"/>
</scr:component>
Then I could successfully consume it on a different PC using zookeeper.
However I would not be able to deploy the service onto another host computer, since the IP address is hard coded in it.
Could you please suggest how I could dynamically set the IP, while still using DS?
Marton
| Re: (no subject) [message #732303 is a reply to message #717753] |
Tue, 04 October 2011 09:17   |
Greetings,
not setting the ecf.exported.containerfactoryargs property and using Zookeeper results in the service being published under the machine's name instead of its IP.
I see:
ZooDiscovery> Service Published: 4-ott-2011 15.11.37. ServiceInfo[uri=ecf.osgirsvc://stefghiow:2794/osgirsvc_JgIBi/vAgO9XkT01C4CmbjAFc/c=;id=ServiceID[type=ServiceTypeID[typeName=_ecf.osgirsvc._default.default._iana];location=ecf.osgirsvc://stefghiow:2794/osgirsvc_JgIBi/vAgO9XkT01C4CmbjAFc/c=;full=_ecf.osgirsvc._default.default._iana@ecf.osgirsvc://stefghiow:2794/osgirsvc_JgIBi/vAgO9XkT01C4CmbjAFc/c=];priority=0;weight=0;props=ServiceProperties[{endpoint.service.id=1, component.name=it.eng.test.remote.ds.helloservice, objectClass=it.eng.test.remote.ds.hello.IHello, endpoint.framework.uuid=d0955d63-8aee-0010-1e9d-bc502ee85ecd, remote.intents.supported=passByValue exactlyOnce ordered, ecf.endpoint.id.ns=org.eclipse.ecf.core.identity.StringID, remote.configs.supported=ecf.generic.server, endpoint.id=ecftcp://stefghiow:2794/server, component.id=0, service.imported.configs=ecf.generic.server}]]
While if I set that property as:
<property name="ecf.exported.containerfactoryargs" type="String" value="ecftcp://192.168.23.28:6666/hello"/>
I see:
ZooDiscovery> Service Published: 4-ott-2011 15.13.26. ServiceInfo[uri=ecf.osgirsvc://192.168.23.28:6666/osgirsvc_Tz1f2EzTCQo7EjICfaKZ8qSC7JI=;id=ServiceID[type=ServiceTypeID[typeName=_ecf.osgirsvc._default.default._iana];location=ecf.osgirsvc://192.168.23.28:6666/osgirsvc_Tz1f2EzTCQo7EjICfaKZ8qSC7JI=;full=_ecf.osgirsvc._default.default._iana@ecf.osgirsvc://192.168.23.28:6666/osgirsvc_Tz1f2EzTCQo7EjICfaKZ8qSC7JI=];priority=0;weight=0;props=ServiceProperties[{endpoint.service.id=1, component.name=it.eng.test.remote.ds.helloservice, objectClass=it.eng.test.remote.ds.hello.IHello, endpoint.framework.uuid=a0b036a4-8aee-0010-12c9-f96c32002514, remote.intents.supported=passByValue exactlyOnce ordered, ecf.endpoint.id.ns=org.eclipse.ecf.core.identity.StringID, remote.configs.supported=ecf.generic.server, endpoint.id=ecftcp://192.168.23.28:6666/hello, component.id=0, service.imported.configs=ecf.generic.server}]]
The only difference is that IP:PORT which I hardcoded is used instead of HOSTNAME:RANDOM_PORT. The problem is, other hosts are not able to resolve the HOSTNAME, I would have to configure them all to resolve it to the right IP.
How can Zookeeper be set to use the machine's IP instead of the hostname when publishing services without that property set?
Thank you,
regards
| Re: (no subject) [message #735240 is a reply to message #734753] |
Tue, 11 October 2011 06:06  |
Greetings,
not quite, that thread was about how to configure replicated and centralized zookeeper modes but the problem depicted here still applies.
I'm asking how to make Zookeeper broadcast the host's IP instead of its hostname when the property ecf.exported.containerfactoryargs is not set.
This is a problem since it would require every other host to be able to correctly resolve the hostnames.
For example, if the property is set Zookeeper broadcasts this information:
otherwise it will say:
In the latter, other machines are not able to resolve stefghiow to the right IP unless they rely on a router or hosts file, which I don't want to.
have a nice day, or night, wherever you are
[Updated on: Tue, 11 October 2011 06:06] by Moderator
FUDForum. Page generated in 0.33971 seconds
