Home » Archived » XML Schema Definition (XSD) » write out part of the loaded schema
write out part of the loaded schema [message #71612] Tue, 20 February 2007 14:57 Go to next message
Originally posted by: Atish.Das.ugs.com
I am using XML Schema Infoset to load a "myschema.xsd". Once it is loaded I
would like to create sub xsd files that contain a sub set of the elements
loaded from "myschema.xsd". The subsets that I want to write out may have
dependent complex types which should also needs to be written out.
For example. Here is my xsd-
<xsd:complexType name="MyType">
<xsd:complexContent>
<xsd:extension base="xyz:MyBaseType">
<xsd:attribute name="arch_type" type="xsd:string" />
<xsd:attribute name="arch_elem_id" type="xsd:string" />
</xsd:extension>
</xsd:complexContent>
</xsd:complexType>
<xsd:element name="MyElement" type="xyz:MyType" />
<xsd:complexType name="MyBaseType">
</xsd:complexType>
XSDSchema schema = loadSchema("myschema.xsd")
Resource mysubset = resourceSet.createResource("mysubset.xml")
XSDElementDeclaration element= (XSDElementDeclaration )
schema.getElement...("MyElement");
mysubset.getcontents().add(element)
resource.save(null)
Here when I save "MyElement" I would like to have all its depndents
"MyBaseType" and "MyType" also saved.
The only way I can do this, is I resolve these dependencies and add them to
the resource and save it.
Is there a convenient way in Schema Infoset to save a subset of the loaded
schema?
Re: write out part of the loaded schema [message #71631 is a reply to message #71612] Tue, 20 February 2007 15:23 Go to previous message
Atish,
There are no built-in utilities to do this.
> </xsd:extension>
> </xsd:complexType>
> </xsd:complexType>
> resource.save(null)
> schema?
Re: write out part of the loaded schema [message #602137 is a reply to message #71612] Tue, 20 February 2007 15:23 Go to previous message
Atish,
> </xsd:extension>
> </xsd:complexType>
> </xsd:complexType>
> resource.save(null)
> schema?
Previous Topic:write out part of the loaded schema
Next Topic:an issue when using the xml schema editor to show the reference element...
Current Time: Fri Sep 12 23:33:24 EDT 2025
Powered by FUDForum. Page generated in 0.04198 seconds
