Home » Eclipse Projects » Remote Application Platform (RAP) » Resource Manager getResource problem
Resource Manager getResource problem [message #71032] Tue, 22 January 2008 11:19 Go to next message
I am trying to get a resource froim the application packages. I use
this :
RWT.getResourceManager().getResource("ro/val/resource.txt")
this returns null
if I try to register the resource with
RWT.getResourceManager().register("ro/val/resource.txt")
I get exception :
Caused by: java.io.IOException: Resource to read not found:
ro/val/resource.txt
at
org.eclipse.rwt.internal.resources.ResourceUtil.openStream(R esourceUtil.java:228)
at
org.eclipse.rwt.internal.resources.ResourceUtil.readBinary(R esourceUtil.java:177)
at
org.eclipse.rwt.internal.resources.ResourceUtil.read(Resourc eUtil.java:46)
the resource.txt file is in the source path in the ro.val package
Thanks for any help,
Val
Re: Resource Manager getResource problem [message #71058 is a reply to message #71032] Tue, 22 January 2008 11:57 Go to previous messageGo to next message
Another thing, if I use
this.getClass().getResource("/ro/val/resource.txt") it works
Val wrote:
> Hi
> this :
> this returns null
> I get exception :
> ro/val/resource.txt
> at
> at
> at
> Val
Re: Resource Manager getResource problem [message #71274 is a reply to message #71058] Wed, 23 January 2008 18:28 Go to previous messageGo to next message
Originally posted by: rherrmann.innoopract.com
Val,
you need to specify the class-loader that has access to the resources in
your plug-in (see
org.eclipse.rwt.resources.IResourceManager#setContextLoader) .
Rüdiger
> Val wrote:
>> Hi
>> this :
>> this returns null
>> I get exception :
>> ro/val/resource.txt
>> at
>> at
>> at
>> Val
Re: Resource Manager getResource problem [message #71613 is a reply to message #71274] Thu, 24 January 2008 12:53 Go to previous messageGo to next message
Thanks for the info, it works now :)
Rüdiger Herrmann wrote:
> Val,
> your plug-in (see
> Cheers,
> Rüdiger
>> Val wrote:
>>> Hi
>>> use this :
>>> this returns null
>>> I get exception :
>>> ro/val/resource.txt
>>> at
>>> at
>>> at
>>> Val
Re: Resource Manager getResource problem [message #71839 is a reply to message #71274] Mon, 28 January 2008 03:40 Go to previous messageGo to next message
Unfortunately I still have some problems,
I do not know which ContextClassLoader to set on the ResourceManager
I have tried with calling
RWT.getResourceManager().setContextLoader(Thread.currentThre ad().getContextClassLoader());
in the start method of the plugin activator
I still get the error : failed to register, Caused by:
java.io.IOException: Resource to read not found: ro/val/resource.txt
> Val,
> your plug-in (see
> Cheers,
> Rüdiger
>> Val wrote:
>>> Hi
>>> use this :
>>> this returns null
>>> I get exception :
>>> ro/val/resource.txt
>>> at
>>> at
>>> at
>>> Val
Re: Resource Manager getResource problem [message #72558 is a reply to message #71839] Fri, 01 February 2008 05:05 Go to previous message
Val,
you need to set the ResourceManagers' context-classloader just before
you register the resource and reset it to its previous value afterwards.
If there is a class that resides in the same package as the resource to
load, its classloader would be a good candidate. Usually, any class that
resides in the same bundle should do (special cases left aside, they all
share the same classloader).
Typical code could look like this:
IResourceManager manager = ResourceManager.getInstance();
ClassLoader buffer = manager.getContextLoader();
manager.setContextLoader( <YourClass>.class.getClassLoader() );
try {
// register resource
} finally {
manager.setContextLoader( buffer );
HTH
Rüdiger
> Thanks
>> Val,
>> in your plug-in (see
>> Cheers,
>> Rüdiger
>>> Val wrote:
>>>> Hi
>>>> use this :
>>>> this returns null
>>>> I get exception :
>>>> ro/val/resource.txt
>>>> at
>>>> at
>>>> at
>>>> Val
Previous Topic:Problem with patch fragments
Next Topic:Do you replace Classes in rt.jar?
Current Time: Sun Aug 31 21:07:51 EDT 2025
Powered by FUDForum. Page generated in 0.04229 seconds
