Home » Eclipse Projects » EclipseLink » (no subject) [solved]
(no subject) [solved] [message #715812] Mon, 15 August 2011 11:52 Go to next message
Hello @all
i have got a problem with my GWT application. I'm using GWT 2.3, EclipseLink 2.3 and mysql with a xampp.
Everythink is working fine. I have got 3 classes in my db: Employee, Times and today i add BonusSalary. All classes are in the persistence.xml.
If i try to add, delete or modify somethink it is working well, but not with my new class BonusSalary.
if i execute this, 10 times from my gwt application it works 5 times.
EntityManager em = factory.createEntityManager();
Query q = em.createQuery("select count(e) from BonusSalary e");
here you can see what i get.
[EL Fine]: 2011-08-15 17:21:43.605--ServerSession(13373134)--Connection(18550117)--Thread(Thread[btpool0-6,5,main])--SELECT COUNT(DBID) FROM BONUSSALARY
[EL Fine]: 2011-08-15 17:21:45.29--ServerSession(13373134)--Connection(18550117)--Thread(Thread[btpool0-6,5,main])--SELECT COUNT(DBID) FROM BONUSSALARY
[EL Fine]: 2011-08-15 17:21:46.257--ServerSession(13373134)--Connection(18550117)--Thread(Thread[btpool0-6,5,main])--SELECT COUNT(DBID) FROM BONUSSALARY
an then suddenly, out of nowhere....
[WARN] Exception while dispatching incoming RPC call
com.google.gwt.user.server.rpc.UnexpectedException: Service method 'public abstract java.util.ArrayList de.octavia.reporting.client.services.ConnectionService.getDBSalaryContent()' threw an unexpected exception: java.lang.IllegalArgumentException: An exception occurred while creating a query in EntityManager:
Exception Description: Error compiling the query [select count(e) from BonusSalary e]. Unknown entity type [BonusSalary].
at com.google.gwt.user.server.rpc.RPC.encodeResponseForFailure(RPC.java:385)
at com.google.gwt.user.server.rpc.RPC.invokeAndEncodeResponse(RPC.java:588)
if i try i again and again, sometimes it is working. i can't believe it. The entity is load and it musst be working!!!!! But it won't work. The other entities are working fine.
1000 times on the gwt button, everytime the correct answer from eclipselink. But not this f*****g new class.
here is the config log:
[EL Config]: 2011-08-15 17:27:34.801--ServerSession(13907210)--Thread(Thread[btpool0-3,5,main])--The access type for the persistent class [class de.octavia.reporting.shared.Times] is set to [PROPERTY].
[EL Config]: 2011-08-15 17:27:34.839--ServerSession(13907210)--Thread(Thread[btpool0-3,5,main])--The access type for the persistent class [class de.octavia.reporting.shared.Employee] is set to [PROPERTY].
[EL Config]: 2011-08-15 17:27:34.841--ServerSession(13907210)--Thread(Thread[btpool0-3,5,main])--The access type for the persistent class [class de.octavia.reporting.shared.BonusSalary] is set to [PROPERTY].
if i try to execute something like that:
select e from BonusSalary e WHERE e.relevantMonth = :relevantMonth and e.employeeID = :emID
that is happening.
Starting Jetty on port 8888
com.google.gwt.user.server.rpc.UnexpectedException: Service method 'public abstract de.reporting.shared.BonusSalary de.octavia.reporting.client.services.ConnectionService.getSalaryWithEmIDrelevantMonth(int,int)' threw an unexpected exception: java.lang.IllegalArgumentException: An exception occurred while creating a query in EntityManager:
Exception Description: Error compiling the query [select e from BonusSalary e WHERE e.relevantMonth = :relevantMonth and e.employeeID = :emID]. Unknown entity type [BonusSalary].
if i try it from a JUnit test, the same method using the same class DBService its working, 1000 times....
this is the method:
EntityManagerFactory f = Persistence.createEntityManagerFactory("xxxxxxxxx");
EntityManager emt = f.createEntityManager();
Query q = emt.createQuery("select e from BonusSalary e WHERE e.relevantMonth = :relevantMonth and e.employeeID = :emID");
q.setParameter("relevantMonth", relevantMonth);
q.setParameter("emID", emID);
@SuppressWarnings("rawtypes")
List list = q.getResultList();
salary = (BonusSalary) list.get(0);
emt.clear();
emt.close();
i can't see the bug or my mistake.....
does anyone have an idea?
here is the code from the new class:
/* some importing stuff */
import javax.persistence.Column;
import javax.persistence.Entity;
import javax.persistence.GeneratedValue;
import javax.persistence.GenerationType;
import javax.persistence.Id;
import javax.persistence.Temporal;
import javax.persistence.TemporalType;
@Entity
public class BonusSalary implements Serializable{
private static final long serialVersionUID = -6427354534163093973L;
private int dbID;
private int employeeID;
private Date lastChange = new Date();
public BonusSalary (){
@Id
@GeneratedValue(strategy = GenerationType.TABLE)
public int getDBID() {
return dbID;
public void setDBID(int dbID) {
this.dbID = dbID;
public int getEmployeeID() {
return employeeID;
public void setEmployeeID(int employeeID) {
this.employeeID = employeeID;
@Temporal( value = TemporalType.TIMESTAMP )
@Column( nullable = false )
public Date getLastChange() {
return lastChange;
public void setLastChange(Date lastChange) {
this.lastChange = lastChange;
/* the class has 20 other variables, but i think they are not important,
they don't have any jpa signs */
so please help me!
[Updated on: Tue, 16 August 2011 02:22] by Moderator
Re: (no subject) [solved] [message #715969 is a reply to message #715812] Tue, 16 August 2011 02:23 Go to previous message
can anybody please delete this double post?!
(no subject) [message #715975 is a reply to message #715812] Tue, 16 August 2011 02:21 Go to previous message
after hours.... i did'n find the bug... the last chance, i saw, was setting up a new project with my code. I do this and suddenly it works. All the time, unbelievable.
I didn't change anythink, nothing, only copy the code in a new GWT project, one time compiling and it works, wtf?????
best regards
(no subject) [message #715976 is a reply to message #715812] Tue, 16 August 2011 02:23 Go to previous message
Previous Topic:Sometimes, unknown entity type, !? [Solved]
Next Topic:(no subject)
Current Time: Sat Jul 26 23:25:37 EDT 2025
Powered by FUDForum. Page generated in 0.04716 seconds
