Home » Modeling » TMF (Xtext) » Model instance( derived from the metamodel .ecore) to Java code using xtend2
Model instance( derived from the metamodel .ecore) to Java code using xtend2 [message #705147] Fri, 29 July 2011 09:51 Go to next message
I'm new to xtend2.
I have defined metamodel(my.ecore) then created the model instance like (aaa.my) I would like to refer this model instance in xtend2 template to generate java code.
I donot want to use the xtext grammar to generate the (.ecore file ) since I already have one.
Is there a way how I can achieve this , i can imagine writing the mwe2 file( in a way we write .mwe file to read the model instance and the xpand template file(.xpt)) but have no idea what this file consists of.
Thanks in advance
[Updated on: Fri, 29 July 2011 09:55] by Moderator
Re: Model instance( derived from the metamodel .ecore) to Java code using xtend2 [message #705387 is a reply to message #705147] Fri, 29 July 2011 16:15 Go to previous messageGo to next message
i just blogged on this
http://christiandietrich.wordpress.com/2011/07/29/xtend2-code-generators-with-non-xtext-models/
~Christian
[Updated on: Fri, 29 July 2011 16:18] by Moderator
Re: Model instance( derived from the metamodel .ecore) to Java code using xtend2 [message #708891 is a reply to message #705387] Wed, 03 August 2011 05:03 Go to previous messageGo to next message
Thanks Christian for the above article, this was very helpful.
Chandan
[Updated on: Mon, 15 August 2011 04:52] by Moderator
Re: Model instance( derived from the metamodel .ecore) to Java code using xtend2 [message #715722 is a reply to message #708891] Mon, 15 August 2011 06:01 Go to previous messageGo to next message
Is there a way to invoke xtend2(.xtend) template from java code instaed of using (mwe2 file). I searched a lot but didn't find any example, though I found an example on how to invoke Xpand template from java code but this is not exactly what I want.
Any help here would be appreciated.
Thanks in advance
~Chandan
[Updated on: Mon, 15 August 2011 06:02] by Moderator
Re: Model instance( derived from the metamodel .ecore) to Java code using xtend2 [message #715723 is a reply to message #715722] Mon, 15 August 2011 06:03 Go to previous messageGo to next message
normally an Xtend2-Template is compiled into a java class which you can "invoke".
Alex
Re: Model instance( derived from the metamodel .ecore) to Java code using xtend2 [message #715814 is a reply to message #715723] Mon, 15 August 2011 12:20 Go to previous messageGo to next message
Alex, I can understand that would be a normal java method invocation.
This is what i can think of now to test the Template invocation through java :
I created a test class to test this.
public class Test {
* @param args
// Initialize the model
StatemachinePackage.eINSTANCE.eClass();
MyDslGenerator myDslGenerator = new MyDslGenerator(); // java class for the Xtend template
// Obtain a new resource set
ResourceSet resourceSet = new ResourceSetImpl();
// Register the XMI resource factory for the .statemachine extension
resourceSet
.getResourceFactoryRegistry()
.getExtensionToFactoryMap()
.put("statemachine", new XMIResourceFactoryImpl());
Resource resource = resourceSet.getResource(URI.createURI("model/My.statemachine"), true);
myDslGenerator.doGenerate(resource, new JavaIoFileSystemAccess());
But Now I'm getting this exception :
Exception in thread "main" java.lang.IllegalArgumentException: A slot with name 'DEFAULT_OUTPUT' has not been configured.
at org.eclipse.xtext.generator.JavaIoFileSystemAccess.generateFile(JavaIoFileSystemAccess.java:23)
at org.eclipse.xtext.generator.AbstractFileSystemAccess.generateFile(AbstractFileSystemAccess.java:34)
at test.MyDslGenerator.doGenerate(MyDslGenerator.java:30)
at test.Test.main(Test.java:30)
I dont know how to initialize the slot or am I doing something wrong here.
~Chandan
Re: Model instance( derived from the metamodel .ecore) to Java code using xtend2 [message #715838 is a reply to message #715814] Mon, 15 August 2011 13:47 Go to previous messageGo to next message
maybe you should follow the error message and configure your JavaIoFileSystemAccess()
see org.eclipse.xtext.generator.GeneratorComponent.getConfiguredFileSystemAccess()
~Christian
Re: Model instance( derived from the metamodel .ecore) to Java code using xtend2 [message #715840 is a reply to message #715814] Mon, 15 August 2011 13:53 Go to previous messageGo to next message
if I create a new Xtext project and run the workflow, a generator package is generated as well. It contains a Main.java containing the following lines (note the comment)
// configure and start the generator
fileAccess.setOutputPath("src-gen/");
generator.doGenerate(resource, fileAccess);
Alex
Re: Model instance( derived from the metamodel .ecore) to Java code using xtend2 [message #716018 is a reply to message #715838] Tue, 16 August 2011 04:27 Go to previous messageGo to next message
Thnx Christian. I got it how to configure.
~Chandan
Re: Model instance( derived from the metamodel .ecore) to Java code using xtend2 [message #716019 is a reply to message #715840] Tue, 16 August 2011 04:28 Go to previous messageGo to next message
Thnx Alex. I got the generator to work
~Chandan
Re: Model instance( derived from the metamodel .ecore) to Java code using xtend2 [message #718128 is a reply to message #715722] Tue, 23 August 2011 06:47 Go to previous message
Xtend2 is compiled to java, so why not call the generated Java method?
Am 15.08.11 12:01, schrieb Chandan:
> Is there a way to invoke xtend2(.xtend) template from java code. I
> I want.
> Thanks in advance
> ~Chandan
Previous Topic:Folding swallowed newlines
Next Topic:GMF synchronization with XTEXT2
Current Time: Wed Jul 23 13:25:15 EDT 2025
Powered by FUDForum. Page generated in 0.23373 seconds
