Home » Archived » Jubula » Referenced Testcase could not be found(Problems importing Project.XML file)
Referenced Testcase could not be found [message #715601] Sun, 14 August 2011 15:01 Go to next message
After attending a very interesting seminar at Bredex last week. I am starting to bring GUI-Tests to Elexis, a program for all aspect of a medical practice (see www.elexis.ch). I also did setup an Mercurial repository with my tests under
https: //bitbucket.org/ngiger/jubula-elexis
As part of integrating these GUI tests into our Jenkins CI-Server I added a small script shell script https: //bitbucket.org/ngiger/jubula-elexis/src/90c2c6f1a71d/run_sample_test.sh, which runs fine on my Debian Linux x86_64 system (testing).
My Jenkins server is a similar machine, but there the script fails with
20:28:37 Sun Aug 14 20:28:37 CEST 2011 Resolving Test Steps to execute...
20:28:37 !!Error occurred !!
20:28:37 Referenced Testcase could not be found.
Details can be found here
http: //ngiger.dyndns.org/jenkins/job/jubula-elexis-2.1.5.x/11/console
I have no clue (but outputting at least the first missing Referenced Testcase would have helped). I tried to clean up every directory used by this test beforehand. Did I miss anything?
Best regards
Niklaus
Re: Referenced Testcase could not be found [message #715689 is a reply to message #715601] Mon, 15 August 2011 04:31 Go to previous messageGo to next message
Hello Niklaus,
The most likely cause is that the "unbound modules" projects for "concrete, swt and rcp" are missing from the database on the second machine. If you open the project directly there, then you will probably see a similar error message.
You can import the projects by following the instructions in chapter "3.8.2.2 Information about the library".
Hope that helps!
Alex
Re: Referenced Testcase could not be found [message #722078 is a reply to message #715689] Sun, 04 September 2011 05:52 Go to previous message
Actually the solution was quite simple.
You first had to import all referenced testcases.
(Via the Jubula GUI this is done automatically)
Previous Topic:How to source control the test scripts
Next Topic:Editing AUT Configuration in New Project wiz is very slow
Current Time: Sun Jul 27 08:01:32 EDT 2025
Powered by FUDForum. Page generated in 0.03719 seconds
