Home » Modeling » Graphiti » Adding Shapes Programmatically
Adding Shapes Programmatically [message #705480] Fri, 29 July 2011 19:30 Go to next message
Started to explore the Graphiti little bit and it seems to provide lots of capabilities. The task which I'm working towards to now is to create a diagram representing the the business model (it is a class diagram I'm trying to create) consisting of many classes. I would like to show only the read-only editor where in application shows the model.
I have opened the Graphiti editor and it is showing with empty area and empty palette. Now the question is, how do I add the existing business model objects into the diagrams?
Thank you for your time to reply and any help is appreciated.
Re: Adding Shapes Programmatically [message #707120 is a reply to message #705480] Mon, 01 August 2011 05:07 Go to previous messageGo to next message
Am 30.07.2011 01:30, schrieb Santhosh:
Hi Santosh,
you have to implement AddFeatures for the business elements you want to
show and build an UpdateFeature for the root business feature (the one
that is represented by the diagram figure) that delegates to the
AddFeatures for each element that should be added.
So in your UpdateFeature identify the business objects to add and do
something like this for each of them:
EObject eobject = <<the element to add>>
AddContext context2 = new AddContext();
context2.setNewObject(eobject);
context2.setLocation(x, y);
context2.setSize(width, height);
context2.setTargetContainer((ContainerShape) pictogramElement);
getFeatureProvider().addIfPossible(context2);
Moreover if you want the update to happen automatically you need to
overwrite isAutoUpdateAtStartup() to return true in your
DiagramTypeProvider class
Veit
Re: Adding Shapes Programmatically [message #715652 is a reply to message #707120] Sun, 14 August 2011 23:50 Go to previous messageGo to next message
Hi Veit,
Thank you for your reply. I did what you suggested below. Execution is coming to AddFeature.add method. I'm creating a container shape corresponding to the resource. When I tried to link it (as shown in Graphiti tutorial example), I'm getting an exception
org.eclipse.core.runtime.AssertionFailedException: null argument: Business object com.brsanthu.rfe.sfdcobjectmodel.impl.SfdcObjectImpl@12231e35 (name: Test) is not contained in a resource
Full exception is at pastebin.com/Wke8UXhj
Here is the Add feature code (modified over tutorial example).
    public PictogramElement add(IAddContext context) {
        SfdcObject object = (SfdcObject) context.getNewObject();
        Diagram targetDiagram = (Diagram) context.getTargetContainer();
        // CONTAINER SHAPE WITH ROUNDED RECTANGLE
        IPeCreateService peCreateService = Graphiti.getPeCreateService();
        ContainerShape containerShape =
             peCreateService.createContainerShape(targetDiagram, true);
        // define a default size for the shape
        int width = 100;
        int height = 50;
        IGaService gaService = Graphiti.getGaService();
            // create and set graphics algorithm
            RoundedRectangle roundedRectangle =
                gaService.createRoundedRectangle(containerShape, 5, 5);
            roundedRectangle.setForeground(manageColor(CLASS_FOREGROUND));
            roundedRectangle.setBackground(manageColor(CLASS_BACKGROUND));
            roundedRectangle.setLineWidth(2);
            gaService.setLocationAndSize(roundedRectangle,
                context.getX(), context.getY(), width, height);
            // create link and wire it
            link(containerShape, object);
        // SHAPE WITH LINE
            // create shape for line
            Shape shape = peCreateService.createShape(containerShape, false);
            Polyline polyline =
                gaService.createPolyline(shape, new int[] { 0, 20, width, 20 });
            polyline.setForeground(manageColor(CLASS_FOREGROUND));
            polyline.setLineWidth(2);
        // SHAPE WITH TEXT
            // create shape for text
            // create and set text graphics algorithm
            Text text = gaService.createDefaultText(getDiagram(), shape, object.getName());
            text.setForeground(manageColor(CLASS_TEXT_FOREGROUND));
            text.setHorizontalAlignment(Orientation.ALIGNMENT_CENTER);
            text.setVerticalAlignment(Orientation.ALIGNMENT_CENTER);
            text.getFont().setBold(true);
            gaService.setLocationAndSize(text, 0, 0, width, 20);
            link(shape, object);
        return containerShape;
Re: Adding Shapes Programmatically [message #717110 is a reply to message #705480] Fri, 19 August 2011 06:53 Go to previous message
Santosh,
another alternative to solve this is implemented in the tutorial. The
"Create Diagram with all Classes" context menu entry (defined in plugin.xml)
creates a new diagram and adds all existing classes of the project to it.
The functionlity is implemented in the classes AddAllClassesCommand and
CreateDiagramWithAllClassesHandler.
Michael
"Santhosh" schrieb im Newsbeitrag news:j0vf70$joc$1@news.eclipse.org...
Previous Topic:TransactionalEditing Domain problem
Next Topic:Root domain object linked to Diagram?
Current Time: Sun Jul 27 08:06:01 EDT 2025
Powered by FUDForum. Page generated in 0.04817 seconds
