Home » Archived » Test and Performance Tools Platform (TPTP) » Automated GUI Tester
Automated GUI Tester [message #71086] Tue, 16 May 2006 21:40 Go to next message
Originally posted by: daniel_heinlein.mentor.com
Dear NewsGroup,
I am researching GUI testing (specifically, Eclipse plugin GUI testing)
and came across the Eclipse TPTP. I attempted to create a new test suite
in Eclipse, but when I went to edit the suite, the editor could not be
loaded (a NoClassDefFound exception was thrown).
Steps to Reproduce:
- Follow the instructions in
http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI.html
until you arrive at section 2.1, then take a look at the main editor pane.
Am I missing a Class? Or is it just not in the classpath?
Daniel Heinlein
Re: Automated GUI Tester [message #71207 is a reply to message #71086] Wed, 17 May 2006 14:42 Go to previous messageGo to next message
Some more info:
Info 2006-05-17 11:40:26.607 org.eclipse.core.runtime.CoreException:
Plug-in org.eclipse.tptp.test.auto.gui was unable to load class
org.eclipse.tptp.test.auto.gui.internal.editor.AutoGUIEditor Extension.
org.eclipse.core.runtime.CoreException[1]: java.lang.NoClassDefFoundError:
org/eclipse/hyades/test/tools/ui/common/internal/editor/Test SuiteEditorExt
at java.lang.ClassLoader.defineClass1(Native Method)
at java.lang.ClassLoader.defineClass(Unknown Source)
at
org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.d efineClass(DefaultClassLoader.java:370)
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.defineCl ass(EclipseClassLoader.java:233)
at
org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.f indClassImpl(DefaultClassLoader.java:343)
at
org.eclipse.osgi.framework.adaptor.core.DefaultClassLoader.f indClass(DefaultClassLoader.java:235)
at
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. findLocalClass(AbstractClassLoader.java:183)
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.basicFin dLocalClass(EclipseClassLoader.java:141)
at
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:68)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:337)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:389)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:350)
at
org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader. loadClass(AbstractClassLoader.java:78)
at
org.eclipse.osgi.framework.internal.core.BundleLoader.loadCl ass(BundleLoader.java:275)
at
org.eclipse.osgi.framework.internal.core.BundleHost.loadClas s(BundleHost.java:227)
at
org.eclipse.osgi.framework.internal.core.AbstractBundle.load Class(AbstractBundle.java:1248)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:152)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:142)
at
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:129)
at
org.eclipse.core.internal.registry.ConfigurationElementHandl e.createExecutableExtension(ConfigurationElementHandle.java: 48)
at
org.eclipse.hyades.ui.internal.extension.AssociationDescript or.getImplementationClass(AssociationDescriptor.java:218)
at
org.eclipse.hyades.ui.internal.extension.AssociationDescript or.createImplementationClassInstance(AssociationDescriptor.j ava:235)
at
org.eclipse.hyades.ui.internal.editor.HyadesEditorPart.init( HyadesEditorPart.java:392)
at
org.eclipse.ui.internal.EditorManager.createSite(EditorManag er.java:778)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:596)
at
org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:384)
at
org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:552)
at
org.eclipse.ui.internal.EditorReference.getEditor(EditorRefe rence.java:223)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2362)
at
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2295)
at org.eclipse.ui.internal.WorkbenchPage.access$9(WorkbenchPage .java:2287)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2273)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:69)
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2268)
at org.eclipse.ui.actions.OpenWithMenu.openEditor(OpenWithMenu. java:279)
at org.eclipse.ui.actions.OpenWithMenu.access$0(OpenWithMenu.ja va:271)
at
org.eclipse.ui.actions.OpenWithMenu$2.handleEvent(OpenWithMe nu.java:178)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :66)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3125)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2758)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
at
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Re: Automated GUI Tester [message #71406 is a reply to message #71207] Sat, 20 May 2006 18:39 Go to previous messageGo to next message
Did you remember to download the 'testing tools' plug-ins?
At a minimum you'll need:
- Platform (Runtime/SDK)
- Testing Tools (Runtime/SDK)
- Automated GUI Plug-in
I recommend downloading:
- TPTP All (Runtime/SDK)
Look under your plug-in folder and make sure that you have the following
plug-in: "org.eclipse.hyades.test.tools.ui".
"Daniel Heinlein" <daniel_heinlein@mentor.com> wrote in message
news:00ac931d80b1c9f98a2501a3c5889ced$1@www.eclipse.org...
> Some more info:
> at
> at
Loader.java:233)
> at
> at
> at
> at
> at
assLoader.java:68)
> at
oader.java:337)
> at
..java:389)
> at
..java:350)
> at
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at
..java:275)
> at
a:227)
> at
ndle.java:1248)
> at
> at
> at
> at
leExtension(ConfigurationElementHandle.java:48)
> at
> at
ntationClassInstance(AssociationDescriptor.java:235)
> at
..java:392)
> at
> at
a:596)
> at
> at
e.java:552)
> at
> at
va:2362)
> at
> at
> at
> at
> at
java:226)
> at
> at
Re: Automated GUI Tester [message #71563 is a reply to message #71406] Mon, 22 May 2006 12:55 Go to previous messageGo to next message
I've got everything you said I should get, including
org.eclipse.hyades.test.tools.ui, but I've tried it several times and
still have the same problem.
This might be a good time to mention the fact that I get other error
messages as well when following the instructions:
Message 1:
While loading class "org.eclipse.hyades.ui.internal.util.ImageManager",
thread "main" timed out waiting (5000ms) for thread "Worker-0" to finish
starting bundle "org.eclipse.hyades.ui". To avoid deadlock, thread "main"
is proceeding but "org.eclipse.hyades.ui.internal.util.ImageManager" may
not be fully initialized.
Message 2:
While loading class "org.eclipse.hyades.ui.HyadesUIImages", thread "main"
timed out waiting (5000ms) for thread "Worker-0" to finish starting bundle
"org.eclipse.hyades.ui". To avoid deadlock, thread "main" is proceeding
but "org.eclipse.hyades.ui.HyadesUIImages" may not be fully initialized.
Message 3:
java.lang.Throwable: This is the editor Hyades uses to "launch" other
editor.
You should not be seeing this.
at org.eclipse.hyades.ui.HyadesUIPlugin.logError(HyadesUIPlugin .java:243)
at
org.eclipse.hyades.ui.internal.editor.HyadesEditorPart.creat ePages(HyadesEditorPart.java:258)
at
org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:241)
at
org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:609)
at
at
at
at
at
at
at
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2241)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:275)
at org.eclipse.hyades.ui.internal.util.UIUtil.openEditor(UIUtil .java:247)
at
org.eclipse.hyades.test.tools.ui.common.internal.wizard.Test SuiteNewWizard.openEditor(TestSuiteNewWizard.java:134)
at
org.eclipse.hyades.ui.internal.wizard.HyadesNewWizard.perfor mFinish(HyadesNewWizard.java:135)
at
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:676)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:349)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
at org.eclipse.ui.actions.NewWizardAction.run(NewWizardAction.j ava:181)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:996 )
at
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
at
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at
at
at
at
Hope this helps.
Daniel Heinlein
Re: Automated GUI Tester [SOLVED] [message #71580 is a reply to message #71563] Mon, 22 May 2006 13:14 Go to previous message
Well, forget my last message. Apparently I didn't have the runtime
installed correctly, and that was what was giving me the problems.
Thanks for the advice,
Daniel Heinlein
Previous Topic:Profiling web applications
Next Topic:Profile Server (WTP and TPTP)
Current Time: Fri Sep 19 13:32:05 EDT 2025
Powered by FUDForum. Page generated in 0.04142 seconds
