[xbase/xcore] infer and refer to constructor [message #714765] |
Thu, 11 August 2011 08:53  |
Originally posted by:
I'm trying to infer and refer to a JvmConstructor for an
XClass/EClass/GenClass in Xcore. This worked well in a different
project, I could both infer and refer to it. However, in Xcore I use the
same technique, but the scope created for the constructor does not
contain the inferred constructor. During debugging I've noticed that the
EObjectDescriptions seems to contain the XClass, but somehow it doesn't
find the corresponding inferred constructor. I'm not sure I understand
how Xbase translates from an EObject to the corresponding inferred
JvmType, but something seems to be missing.
The only difference in my code between these two projects is how the
constructor is associated with the XClass. In the working one I use an
JvmModelAssociator, while in Xcore a special mapping object is used. I
don't know how this mapping object is used during scoping/linking.
Hallvard
Re: [xbase/xcore] infer and refer to constructor [message #714847 is a reply to message #714765] |
Thu, 11 August 2011 11:15   |
Hallvard,
Hopefully I can get a chance to play with this today to see what's
happening (as well as to fix the other issue you reported).
On 11/08/2011 5:53 AM, Hallvard Trætteberg wrote:
> the same technique, but the scope created for the constructor does not
> the EObjectDescriptions seems to contain the XClass, but somehow it
> doesn't find the corresponding inferred constructor. I'm not sure I
> understand how Xbase translates from an EObject to the corresponding
> inferred JvmType, but something seems to be missing.
> Hallvard
Re: [xbase/xcore] infer and refer to constructor [message #715107 is a reply to message #715079] |
Fri, 12 August 2011 07:28   |
On 12.08.11 11.41, Hallvard Trætteberg wrote:
> I found the missing piece (which I had in the working project)! The
> getFullyQualifiedName method of XcoreQualifiedNameProvider didn't handle
> JvmConstructor objects, only JvmType objects. I changed it to work for
> JvmIdentifiableElement in general (hopefully that's ok) and now the
> inferred constructor is correctly linked to. The next step is to make
> the interpreter handle such a constructor and write some tests to prove it.
The tests revealed that JvmIdentifiableElement was too general, I've
changed it to:
else if (eObject instanceof JvmType || eObject instanceof
JvmConstructor)
String qualifiedName = ((JvmIdentifiableElement)
eObject).getQualifiedName();
return nameConverter.toQualifiedName(qualifiedName);
After overriding XcoreInterpreter's _evaluateConstructorCall, so it
creates the appropriate EObject, the following test now works (as do the
other tests):
@Test
def void testConstructor() {
val pack = parse.parse('''
package foo.bar
class Foo {
String value
op Foo copy() {
val foo = new Foo()
foo.value = value
return foo
validator.assertNoErrors(pack)
val ePackage = pack.eResource.contents.get(2) as EPackage
val fooClass = ePackage.getEClassifier("Foo") as EClass
val foo = ePackage.EFactoryInstance.create(fooClass)
val copy = foo.eInvoke(fooClass.EOperations.head, new BasicEList());
assertTrue(copy instanceof EObject);
assertEquals(fooClass, (copy as EObject).eClass());
val valueFeature = fooClass.getEStructuralFeature("value");
assertEquals(foo.eGet(valueFeature), (copy as
EObject).eGet(valueFeature));
Hallvard
Re: [xbase/xcore] infer and refer to constructor [message #715184 is a reply to message #715107] |
Fri, 12 August 2011 11:44  |
Hallvard,
This sounds cool. :-)
I've been playing with getting the interpreter working in the reflective
editor (by hacking it in a gross way to create an XtextResourceSet).
From the Xcore editor, you can create a dynamic instance of some
XClass's corresponding EClass. The reflective editor loads the *.xcore
resource while loading the instance and after that your operation
invocation view has proven useful. It can be used to invoke the
interpreter on the dynamic instances in the editor. I've committed the
preliminary changes for Xcore and have attached an updated patch in the
bugzilla.
>> Hi,
>> prove it.
> changed it to:
> JvmConstructor)
> the other tests):
> @Test
> package foo.bar
> class Foo {
> String value
> op Foo copy() {
> val foo = new Foo()
> foo.value = value
> return foo
> BasicEList());
> Hallvard
FUDForum. Page generated in 1.04485 seconds
