Home » Modeling » TMF (Xtext) » [mwe2] Resolving platform:/plugin
[mwe2] Resolving platform:/plugin [message #714686] Thu, 11 August 2011 04:59 Go to next message
I need to resolve
platform:/plugin/org.eclipse.xtext.common.types/model/JavaVMTypes.genmodel
within my workflow.
When using CVS, I made do with a URI mapping to a relative path that
required org.eclipse.xtext.common.types to be imported as a project into
the workspace.
Since moving to GIT the relative path collapses; unless I put
org.eclipse.xtext.common.types into my GIT.
The following appears to solve the problem by allowing access to the
true plugin:
Launch with an additional parameter: --param eclipse_home=${eclipse_home}
In the workflow:
var eclipse_home
Workflow {
bean = ResourceSetImpl : resourceSet {}
bean = StandaloneSetup { resourceSet = resourceSet
platformUri = ".."
platformUri = "${eclipse_home}"
registerGeneratedEPackage =
"org.eclipse.xtext.common.types.TypesPackage"
uriMap = Mapping {
from = "platform:/plugin/org.eclipse.xtext.common.types/"
to = "platform:/resource/org.eclipse.xtext.common.types/"
Is there a better way?
Since eclipse_home is rather useful, shouldn't the MWE launcher provide
it automatically?
Perhaps StandaloneSetup should have an "eclipseHome" Property to
configure EcorePlugin's plugin map correctly.
The MWE2 documentation seems to overlook this useful parameter passing
ability.
Is it a bug that platformUri can be set twice?
Ed Willink
Re: [mwe2] Resolving platform:/plugin [message #714849 is a reply to message #714686] Thu, 11 August 2011 11:27 Go to previous messageGo to next message
Hi Ed,
please try to set StandaloneSetup#scanClassPath to true.
That should take care of most of the other configuration that you did.
Sebastian
On 11.08.11 10:59, Ed Willink wrote:
> Hi
> I need to resolve
> within my workflow.
> the workspace.
> true plugin:
> In the workflow:
> var eclipse_home
> Workflow {
> platformUri = ".."
> registerGeneratedEPackage = "org.eclipse.xtext.common.types.TypesPackage"
> uriMap = Mapping {
> it automatically?
> ability.
> Regards
> Ed Willink
Re: [mwe2] Resolving platform:/plugin [message #714941 is a reply to message #714849] Thu, 11 August 2011 15:57 Go to previous messageGo to next message
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
<html>
<head>
<meta content="text/html; charset=ISO-8859-1"
http-equiv="Content-Type">
</head>
<body text="#000000" bgcolor="#ffffff">
Hi Sebastian<br>
<br>
Thanks. Yes, scanClassPath solves the need to mess around with an
eclipse_home, but it is still necessary to have<br>
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; uriMap = Mapping {
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; from = "platform:<i class="moz-txt-slash"><span
class="moz-txt-tag">/</span>plugin/org.eclipse.xtext.common.types<span
class="moz-txt-tag">/</span></i>"
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; to = "platform:<i class="moz-txt-slash"><span
class="moz-txt-tag">/</span>resource/org.eclipse.xtext.common.types<span
<br>
&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp;&nbsp; }
<br>
<br>
which seems a little redundant if scanClasspath has found all the
plugin resources.<br>
<br>
&nbsp;&nbsp;&nbsp; Regards<br>
<br>
&nbsp;&nbsp;&nbsp; &nbsp;&nbsp;&nbsp; Ed Willink<br>
<br>
On 11/08/2011 16:27, Sebastian Zarnekow wrote:
<blockquote cite="mid:j20roc$f9u$2@news.eclipse.org" type="cite">Hi
Ed,
<br>
<br>
<br>
did.
<br>
<br>
<br>
Sebastian
<br>
</blockquote>
<br>
</body>
</html>
Re: [mwe2] Resolving platform:/plugin [message #714942 is a reply to message #714941] Thu, 11 August 2011 16:21 Go to previous messageGo to next message
Hi Ed,
your are right.
Could you please file a ticket and describe your usecase, especially why
you had to use platform:/plugin instead of platform:/resource uris.
Sebastian
On 11.08.11 21:57, Ed Willink wrote:
> Hi Sebastian
> uriMap = Mapping {
> which seems a little redundant if scanClasspath has found all the plugin
> resources.
> Regards
> Ed Willink
>> Hi Ed,
>> Regards,
>> Sebastian
Re: [mwe2] Resolving platform:/plugin [message #715014 is a reply to message #714942] Fri, 12 August 2011 01:15 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=354575
On 11/08/2011 21:21, Sebastian Zarnekow wrote:
> Hi Ed,
> your are right.
> why you had to use platform:/plugin instead of platform:/resource uris.
> Regards,
> Sebastian
Previous Topic:Template proposals despite "Too many constants"
Next Topic:Ctrl+hover does not show hyperlink
Current Time: Sun Jul 20 21:12:33 EDT 2025
Powered by FUDForum. Page generated in 0.05006 seconds
