Home » Eclipse Projects » Eclipse Platform » Bug with CVS?
Bug with CVS? [message #71492] Wed, 11 June 2003 17:23 Go to next message
Originally posted by: kduffey.marketron.com
Hey all, just got the 3.0 M1 release. I don't know if this is a bug or not,
but I didn't see this behavior in the 2.1 release. If someone could verify
that would be great. I have my open source project in SourceForge. When I
open my project in Eclipse, and right-click, Team -> Update, it works fine.
Soon as I do any other team function, I get an IO exception, server was
closed dialog. If I close the project, then reopen it, and do it again, same
thing. I found this out because I did an Update, then added a file and did a
Commit and it kept on giving me this error. Each time, I would close the
project, re-open, update the file, then commit and the update worked, the
commit didn't. To detail more, if I went to the project root dir, updated,
then tried anything on any folder/file within the project, I got the same
error. However, if I reopened the project, selected a file, the first
operation worked, then on nothing worked on that file, but I was able to do
an operation on other files/folders just one time. It appears any "nested"
file/folder loses its ability to have a team/cvs operation performed on it
after the first operation is done.
Re: Bug with CVS? [message #71721 is a reply to message #71492] Thu, 12 June 2003 02:08 Go to previous messageGo to next message
I have same problem with SF.
But only with SF.
When I work with CVS server in local network or other remote CVS server,
Eclipse works fine.
This is known problem, however I am not sure, what author of CVS support
going to do with this.
SY, Konstantin.
Re: Bug with CVS? [message #72275 is a reply to message #71721] Thu, 12 June 2003 12:24 Go to previous messageGo to next message
please log a bug to the VCM component
> But only with SF.
> Eclipse works fine.
Re: Bug with CVS? [message #72453 is a reply to message #72275] Thu, 12 June 2003 14:28 Go to previous messageGo to next message
Is this a bug with Eclipse? Another poster said it is a known bug but only
with sourceforge? I don't know if I should log a bug with eclipse if it is
not due to eclipse? It seems the server at sourceforge disconnects. However,
it wasn't doing this in earlier versions. I'll play with it a bit more
today, if it continues, I'll log it, but let me know if you think this
should be an eclipse bug or not.
"Jean-Michel Lemieux" <jean-michel_lemieux@ca.ibm.com> wrote in message
news:3EE8A95A.50006@ca.ibm.com...
not,
verify
I
fine.
> > But only with SF.
server,
> > Eclipse works fine.
support
Re: Bug with CVS? [message #72523 is a reply to message #72453] Thu, 12 June 2003 14:51 Go to previous messageGo to next message
Originally posted by: Michael_Valenta.oti.com
Kevin,
There is already a bug report for this
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=37559). It is most likely
a server load issue as the command line client also fails during times
when Eclipse fails.
Michael
> not,
> verify
> I
> fine.
>>> But only with SF.
> server,
>>>Eclipse works fine.
> support
Re: Bug with CVS? [message #72541 is a reply to message #72523] Thu, 12 June 2003 14:54 Go to previous message
Great, thanks for pointing that out. I'll not worry about logging it then.
"Michael Valenta" <Michael_Valenta@oti.com> wrote in message
news:3EE8CBAB.1030406@oti.com...
> Kevin,
> when Eclipse fails.
> Michael
only
is
However,
> > not,
> > verify
When
> > I
> > fine.
was
> >>> But only with SF.
> > server,
> >>>Eclipse works fine.
> > support
Previous Topic:JarSelectionDialog?????
Next Topic:JUnit Failure Trace not printed completely
Current Time: Wed Sep 03 22:04:07 EDT 2025
Powered by FUDForum. Page generated in 0.04876 seconds
