Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Input Methods Menu Entry
Input Methods Menu Entry [message #713998] Tue, 09 August 2011 10:56 Go to next message
Hi all,
I have been trying to remove the Input Methods menu entry with absolutely no success. I've googling I has not been able to find the solution. I've tried to set gtk-show-input-method-menu and gtk-show-unicode-menu modifying the .gtkrc-2.0 and using gconftool-2. I have also tried with a Menu Listener to removed the entry before to show. No way. There is also a "org.eclipse.swt.internal.gtk.noInputMethod" constant but apparently does not change the behavior of my control. I'm running Ubuntu Lucid Lynx (10.04) and Eclipse Helios.
Any help? Than you very much in advance.
Joaquin Morcate
Re: Input Methods Menu Entry [message #714854 is a reply to message #713998] Thu, 11 August 2011 11:29 Go to previous messageGo to next message
Hi Joaquin,
A fix was made in this area for non-native controls in 3.7, see
https://bugs.eclipse.org/bugs/show_bug.cgi?id=284777 . Are you using an
earlier Eclipse release than this? Does this address your case?
Grant
On 8/9/2011 10:56 AM, Joaquin Morcate wrote:
> Hi all,
> Joaquin Morcate
Re: Input Methods Menu Entry [message #715994 is a reply to message #714854] Tue, 16 August 2011 03:37 Go to previous messageGo to next message
Hi Grant,
Thanks four your support. We have got some holidays here so I will try today to update my target.
Best Regards
Joaquin Morcate
Re: Input Methods Menu Entry [message #725866 is a reply to message #714854] Thu, 15 September 2011 22:50 Go to previous message
Can this be also related to Bug 284777?
Previous Topic:SWT Table with large number of columns does not display column headers
Next Topic:CheckBoxTableViewer: how to disable the checkboxes
Current Time: Sun Jul 27 11:47:08 EDT 2025
Powered by FUDForum. Page generated in 0.03866 seconds
