Home » Modeling » M2T (model-to-text transformation) » [Acceleo] Metamodel registered, but still...("there are no model elements that matches at least.....")
[Acceleo] Metamodel registered, but still... [message #707935] Tue, 02 August 2011 04:42 Go to next message
I'm creating a plugin for Papyrus, in which I perform M2M and M2T. It works as follows : first, a native metamodel transformation from UML to a dedicated metamodel. Then, an extension point "modelTransformation" is set to accept model transformations from this dedicated metamodel to any other, and it has an attribute "codeGeneration" to link this transformation to a code generation module.
I didn't have any trouble transforming models, but I can't get to launch the code generation. I've got this error
!ENTRY org.eclipse.acceleo.engine 2 0 2011-08-02 10:03:47.137
!MESSAGE The generation fail to generate any file because there are no model elements that matches at least the type of the first parameter of one of your main templates.
The problem may be caused by a problem with the registration of your metamodel, please see the method named "registerPackages" in the Java launcher of your generator.
The metamodel I use isn't registered, it would seem. But it is well registered indeed, as I used the extension org.eclipse.emf.ecore.dynamic_package to get it done, and I can tell it works because (for example) modisco browser can go through the generated xmi.
Let's see then how the code generation is executed :
					public void run() throws Exception {
						((AbstractAcceleoGenerator) codeGen).initialize(URI.createURI(model),currentProject.getFullPath().toFile(), args);
						((AbstractAcceleoGenerator) codeGen).doGenerate(new BasicMonitor());
model is a string containing the full name of the xmi file. The URI created from it contains the first Element (an EClassImpl) of the xmi file. I guess that's how it's supposed to be.
currentProject is the current active IProject, I tested it and it correspond to what's expected.
I tried in the template to replace the package ns uri with a relative and an absolute path, it didn't change a thing (wasn't worse tho).
I should mention that the generation works when executed alone in my dev eclipse instance.
I really don't know what to do. If you could please point me to the right direction, it would help a lot. Thank you for reading all this.
A
[Updated on: Tue, 02 August 2011 05:04] by Moderator
Re: [Acceleo] Metamodel registered, but still... [message #709710 is a reply to message #707935] Thu, 04 August 2011 04:03 Go to previous messageGo to next message
This issue can come from two things : either 1) the metamodel wasn't properly registered, or 2) the input model wasn't loaded as it should. This is an area where we need to enhance Acceleo so that it diagnoses the model loading issues.
I would say that your case is the 2). Please try to change your "model" URI to a fragment-less URI (i.e : "The URI created from it contains the first Element (an EClassImpl) of the xmi file" : remove the "first Element" from the URI). Your URI currently looks like "protocol:/path/to/model.xmi#//EClass1". It should be of the form :
- "platform:/resource/project/path/to/model.xmi" or
- "file:/absolute/path/to/model.xmi" or even
- "platform:/plugin/pluginID/path/to/model.xmi".
Acceleo will handle the search for the "input" EObjects itself. If you have a "main" template that takes an EClass as its input, Acceleo will call the generation for all EClasses contained by your model. Your best bet would be to debug the launch that works ("the generation works when executed alone in my dev eclipse instance") and see what the URI that is used in that case looks like.
Laurent Goubet
Obeo
Re: [Acceleo] Metamodel registered, but still... [message #709763 is a reply to message #709710] Thu, 04 August 2011 05:16 Go to previous messageGo to next message
Hi laurent,
I may haven't be clear about the model URI : it is not a fragment, and its toString() method returns "platform:/resource/ProjectName/ModelName.xmi", what I ment is that modelURI.eResource().getContents() returns "[org.eclipse.emf.ecore.impl.DynamicEObjectImpl@145d3317 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@7c0e4e8c (name: Project) ....". This eClass matches the first template of my .mtl file :
[template public generateProject(aProject : Project)]
Anyway, I'll try to debug the launch that works.
Thank you for your time ! If you think of something else, I'm all ears.
A
Re: [Acceleo] Metamodel registered, but still... [message #709765 is a reply to message #709763] Thu, 04 August 2011 05:18 Go to previous messageGo to next message
By the way, I'm not using the "registerPackages" method, maybe it's a necessary step ?
Re: [Acceleo] Metamodel registered, but still... [message #713211 is a reply to message #709765] Mon, 08 August 2011 04:16 Go to previous messageGo to next message
You can see in the following screenshot an example of the use of Acceleo with a dynamic metamodel. You can even see in this example multiple metamodels in several folders.
https://lh5.googleusercontent.com/-GG07ZkOhGiE/TaWiybT6r0I/AAAAAAAAAbc/H-U1mOt-LpQ/s600/DynamicMetamodelDependencies.png
The registration of the package should not be necessary as long as you are launching your generation with the Acceleo Plugin-in Application runner in the run configuration.
Stephane Begaudeau, Obeo
Twitter: @sbegaudeau
Google+: stephane.begaudeau
Blog: http://stephanebegaudeau.tumblr.com
Acceleo Documentation: http://docs.obeonetwork.com/acceleo
Re: [Acceleo] Metamodel registered, but still... [message #713868 is a reply to message #713211] Tue, 09 August 2011 04:52 Go to previous messageGo to next message
Thanks Stephane, although I'm not launching my generation with the acceleo app runner, but within another plugin by calling the initialize and dogenerate methods. My Acceleo project looks like yours, except the metamodel I use isn't in the acceleo project.
I don't think my problem comes from a bad package registration, but as Laurent said, more from a bad URI. It's weird though because the URI I use is of the form "platform:/resource/projectName/filename.xmi", and it is valid because ATL handles it.
Maybe it comes from the File instance representing the project needed in the initialize method, to get it I did : IProjectInstance.getFullPath().getFile() .
Re: [Acceleo] Metamodel registered, but still... [message #714644 is a reply to message #713868] Thu, 11 August 2011 03:28 Go to previous messageGo to next message
Are you using Acceleo 3.1? If yes, you can improve the way Acceleo handle URIs by switching to the XMI serialization of the Acceleo modules (right click on the project -> properties -> Acceleo -> check XMI). Binary is faster and lighter but XMI is "smarter".
Re: [Acceleo] Metamodel registered, but still... [message #714745 is a reply to message #714644] Thu, 11 August 2011 08:33 Go to previous messageGo to next message
Thank you for your answer Stephane. But I still can't generate code :'-( I've tried everything, I must have done a stupid mistake and yet I just can't see it...
There must be some kind of incompatibility between the registered package and the xmi file, because on the one hand, my metamodel is registered, and on the other hand the xmi file exists (I tried to give bad URI and exceptions were thrown).
This is weird since it works with the same xmi file when running it via eclipse.
Well, I'll keep searching.
[Updated on: Thu, 11 August 2011 10:26] by Moderator
Re: [Acceleo] Metamodel registered, but still... [message #715061 is a reply to message #714745] Fri, 12 August 2011 04:55 Go to previous messageGo to next message
> can't see it...
You may provide us a zipped version of your projects on a bugzilla entry
if possible for you.
It will be easier for us to reproduce your problem and understand what
goes wrong.
Mariot
Mariot Chauvin @ Obeo
Blog : http://mariot-thoughts.blogspot.com
Twitter :http://twitter.com/mchv
Professional support : http://obeo.fr/pages/maintenance-and-support/
Re: [Acceleo] Metamodel registered, but still... [message #715145 is a reply to message #715061] Fri, 12 August 2011 10:12 Go to previous message
Hi, I've created a bug entry : https://bugs.eclipse.org/bugs/show_bug.cgi?id=354619
You may find a zip file containing my projects.
And thank you, by the way.
A
Previous Topic:EMF metamodel with acceleo
Next Topic:[Acceleo] strange behaviour of Acceleo
Current Time: Tue Sep 16 11:28:52 EDT 2025
Powered by FUDForum. Page generated in 0.19385 seconds
