Home » Eclipse Projects » Standard Widget Toolkit (SWT) » (no subject)
(no subject) [message #714725] Thu, 11 August 2011 07:35 Go to next message
Originally posted by:
On 2011-08-11 13:29, vijay wrote:
> What is the underlying reson for having limited no of handles for widgets?
Because this is an OS-specific property.
> why is it not only dependend on the amount of memory available?
It is a very persistent misunderstanding that "resources" and "memory
resources" are not the very same thing. Would you also expect that the
number of open files depends on the available memory? If yes: This is
another misunderstanding, even though the available memory is of-course
a *further* limitation.
> which resource is captured,when u use up a handle by creating a widget?
I don't understand this question. But for feedback reasons it makes
sense to ask, why you need to know this? You should always ensure that
non-Java-memory are properly released, otherwise you will have severe
problems.
HTH & Greetings from Bremen,
Daniel Krügler
Re: (no subject) [message #714732 is a reply to message #714725] Thu, 11 August 2011 07:59 Go to previous messageGo to next message
Please move it to actual post....
Re: (no subject) [message #714737 is a reply to message #714732] Thu, 11 August 2011 08:00 Go to previous messageGo to next message
What is this supposed to mean?
- Daniel
Re: (no subject) [message #714749 is a reply to message #714737] Thu, 11 August 2011 08:42 Go to previous messageGo to next message
My Actual post to which u have replied is this
http://www.eclipse.org/forums/index.php/t/234544/
U r reply is as a new post here with subject as (no subject)..
Re: (no subject) [message #714756 is a reply to message #714749] Thu, 11 August 2011 08:50 Go to previous message
Your message has ended up in "eclipse.platform.swt" and this
is the newsgroup where I replied from.
This is incorrect. In fact, *your* reply to my first reply was the first
one that has the "Re: (no subject)" subject.
- Daniel
Previous Topic:How can I view SWT Image while debugging?
Next Topic:Unable to retrieve the modified cell value in the Table Viewer
Current Time: Sun Jul 27 08:16:14 EDT 2025
Powered by FUDForum. Page generated in 0.04325 seconds
