Home » Modeling » TMF (Xtext) » [xbase] value coercion
[xbase] value coercion [message #714272] Wed, 10 August 2011 04:01 Go to next message
Originally posted by:
I wonder if there is a mechanism for providing rules to xbase for
coercing values, when types don't match (not unlike Scala's implicits).
So instead of getting error markers that some expression has the wrong
type, the error is silently ignored (or perhaps with an info marker), as
if it was rewritten/wrapped to provide a value of the proper type.
This is particularly convenient for functions that take functions as
arguments. E.g. a Class could be coerced to Predicate<Object> to test
for instanceof or a String could be coerced to Predicate<String> for
regexp matching.
Hallvard
Re: [xbase] value coercion [message #714299 is a reply to message #714272] Wed, 10 August 2011 04:59 Go to previous messageGo to next message
Hi Hallvard,
there is the SynonymTypeProvider which allows to define conversions
statically. That is, int is synonym to Integer or Object[] is synonym to
List<Object>. Xtext 2.1 will likely provide such a feature on the type
reference level (XSynonymTypeReference). This would allow to do things
like (pseudocode):
_type(XStringLiteral literal, ..) {
String value = literal.value;
if (value.length == 1) {
if (value contains only digits) {
return synonymtype(typeof(String), typeof(Number), typeof(char));
} else {
return synonymtype(typeof(String), typeof(char));
} else if (value contains only digits) {
return synonymtype(typeof(String), typeof(Number))
} else {
return typeof(String);
Sebastian
On 10.08.11 10:01, Hallvard Trætteberg wrote:
> regexp matching.
> Hallvard
Re: [xbase] value coercion [message #714352 is a reply to message #714299] Wed, 10 August 2011 07:51 Go to previous messageGo to next message
Sebastian,
Looks similar to what I described. It would need to work for general
expressions (compare expected to actual type), not just literals. Where
is the conversion actually implemented, e.g. when/where/how is the code
for converting the string to number generated/injected?
Hallvard
> like (pseudocode):
> } else {
> } else {
> Regards,
> Sebastian
Re: [xbase] value coercion [message #714441 is a reply to message #714352] Wed, 10 August 2011 09:58 Go to previous message
Hi Hallvard,
this cannot work for arbitrary expressions since you (generally) do not
statically know the value of the string if it's not a literal.
This would be the implementation in the ITypeProvider.
Sebastian
On 10.08.11 13:51, Hallvard Trætteberg wrote:
> Sebastian,
> Hallvard
>> like (pseudocode):
>> } else {
>> } else {
>> Regards,
>> Sebastian
Previous Topic:The following token definitions are unreachable: RULE_ID
Next Topic:Enumeration type between ""
Current Time: Sun Jul 27 23:03:43 EDT 2025
Powered by FUDForum. Page generated in 0.09000 seconds
