Home » Archived » BIRT » Missing column(Missing column)
Missing column [message #703295] Wed, 27 July 2011 07:57 Go to next message
Hi All,
I am using a code to generate a report using BIRT.
Here, I am using "Month" in COLUMN of crosstab.
If month have 3 records for ex Jan, Feb, Mar Then cross tab displays that records only.
I want all the Months in column like,
JAN Feb Mar Apr May ...... Dec
26 20 35 - - -
But, Now it displays, First 3 columns.
Plz help me on this
Re: Missing column [message #703435 is a reply to message #703295] Wed, 27 July 2011 10:55 Go to previous messageGo to next message
Is your month dimension set as a date time dimension? If so look at the
empty rows/columns setting for the crosstab. See attached exmaple.
Jason
On 7/27/2011 7:57 AM, jeyinul wrote:
> Hi All,
> that records only.
> 26 20 35 - - -
> Plz help me on this
Re: Missing column [message #704883 is a reply to message #703435] Fri, 29 July 2011 03:05 Go to previous messageGo to next message
Month Column is not datetime.
Its string
Re: Missing column [message #705257 is a reply to message #704883] Fri, 29 July 2011 11:55 Go to previous messageGo to next message
The only way I think you will be able to get this to work (as BIRT will
not know what is missing) is to add entries to your dataset or switch to
a date time dimension.
Jason
> Its string
Re: Missing column [message #707129 is a reply to message #705257] Mon, 01 August 2011 05:17 Go to previous messageGo to next message
Can you tell me how to add in data set.
Plz explain.
Jeyinul.
Re: Missing column [message #707355 is a reply to message #707129] Mon, 01 August 2011 10:24 Go to previous messageGo to next message
What kind of dataset are you using? Is this a JDBC data set?
Jason
> Plz explain.
> Regards,
> Jeyinul.
Re: Missing column [message #712426 is a reply to message #707355] Sun, 07 August 2011 04:28 Go to previous messageGo to next message
Hi jason,
IT is JDBC Data set.
Same kind of Problem i met in Chart. But it is solved by adding the below code in data binding and chart.
if(dimension["Group26"]["mon"]=='Jan'){
1;
}else if(dimension["Group26"]["mon"]=='Feb'){
2;
}else if(dimension["Group26"]["mon"]=='Mar'){
3;
}else if(dimension["Group26"]["mon"]=='Apr'){
4;
else if(dimension["Group26"]["mon"]=='May'){
5;
Now help me in cross tab.
Jeyinul.
[Updated on: Mon, 08 August 2011 06:14] by Moderator
Re: Missing column [message #713659 is a reply to message #712426] Mon, 08 August 2011 14:28 Go to previous messageGo to next message
You could try to add a computed column that converts you month string to
a date.
Jason
On 8/7/2011 4:28 AM, jeyinul wrote:
> IT is JDBC Data set
Re: Missing column [message #713896 is a reply to message #713659] Tue, 09 August 2011 06:30 Go to previous messageGo to next message
Hi jason,
Thanks for your reply.
I tried jason. But it displays error saying that can not convert.
Please let me know some other way or script. I don't the script.
Please send me Jason.
Thanks and Regards,
Jeyinul.
Re: Missing column [message #713990 is a reply to message #713896] Tue, 09 August 2011 10:31 Go to previous messageGo to next message
Add a computed column with an expression similar to this:
var mn = 0;
if( dataSetRow["month"] == "Jan" ){
mn= 0;
if( dataSetRow["month"] == "Feb" ){
mn= 1;
if( dataSetRow["month"] == "Mar" ){
mn= 2;
if( dataSetRow["month"] == "Apr" ){
mn= 3;
if( dataSetRow["month"] == "May" ){
mn= 4;
if( dataSetRow["month"] == "Jun" ){
mn= 5;
new Date(2010, mn, 1, 1, 1, 1, 1);
Set its data type to date.
Jason
On 8/9/2011 6:30 AM, jeyinul wrote:
> Hi jason,
> Thanks and Regards,
> Jeyinul.
Re: Missing column [message #714344 is a reply to message #713990] Wed, 10 August 2011 07:30 Go to previous messageGo to next message
Thanks Jason,
Its working. I tracked that field in "Cross tab - column".
But still i am having the problem to display all the months.
I am using one filter. The filter is Project. It displays the records based on the project. In that Particular project, There are 3 records for Jan, Feb, Mar.
So, it displays the records for only 3 months.
If the month is not having a value then by default it is hidden.
Same Problem Jason.
Can you help me any other way.
Thank you once again for your effort on this.
Jeyinul.
Re: Missing column [message #714499 is a reply to message #714344] Wed, 10 August 2011 12:36 Go to previous message
Did you use the computed column in the data cube and set its type to
date/time? Make sure you have the cross tab set to show empty values.
Look at Empty Rows/Columns property in the property editor. If you have
some way to reproduce the issue it would be better.
Jason
On 8/10/2011 7:30 AM, jeyinul wrote:
> Thanks Jason,
> Its working. I tracked that field in "Cross tab - column". But still i
> for Jan, Feb, Mar.
> Same Problem Jason.
> Regards,
> Jeyinul.
Previous Topic:Birt Report with scripted dataset, Rptdesign Preview issue
Next Topic:Birt in a WebApp
Current Time: Fri Jul 25 08:46:38 EDT 2025
Powered by FUDForum. Page generated in 0.07264 seconds
