Home » Eclipse Projects » JFace » MasterDetails and inital master selection
MasterDetails and inital master selection [message #710639] Fri, 05 August 2011 04:49 Go to next message
Hello all !
I am extensively using th master details pattern of the forms UI. I need one little thing : I would like the master to auto-select its first item when not empty so that details are shown for this element.
It seems harder than expected : if I set the selection during master creation, the item is properly selected in the master, but details are not shown. Afterwards, I don't have the apropriate information to set the selection.
It seems to be done in PDE editors (for example the "extensions" tab), what is the best practice to implement this ?
Thank you very much!
Christophe
http://www.nextep-softwares.com
Re: MasterDetails and inital master selection [message #713826 is a reply to message #710639] Tue, 09 August 2011 02:45 Go to previous message
You need to set the selection after the details parts are registered to master.
In the typical code where master and details are registered add code like following:
	protected void createFormContent(final IManagedForm managedForm) {
		super.createFormContent(managedForm);
		this.managedForm = managedForm;
		this.form = managedForm.getForm();
		this.toolkit = managedForm.getToolkit();
		form.setText("Heading");
		form.setImage("Some image");
		toolkit.decorateFormHeading(form.getForm());
		dtMasterDetailBlock = new EditorMasterDetailBlock(this, file, populateForDTEnumConstant, model, rootDataType, callback, domain);
		Composite formBody = form.getBody();
		formBody.setLayout(new GridLayout(1, false));
		SashForm sashForm = new SashForm(formBody, SWT.NULL);
		GridDataFactory.fillDefaults().grab(true, true).applyTo(sashForm);
		toolkit.adapt(sashForm, false, false);
		dtMasterDetailBlock.createMasterPart(managedForm, sashForm);
		DetailsPart detailsPart = new DetailsPart(managedForm, sashForm, SWT.NULL);
		managedForm.addPart(detailsPart);
		dtMasterDetailBlock.registerPages(detailsPart);
		dtMasterDetailBlock.createToolBarActions(managedForm);
		dtMasterDetailBlock.setInitialSelection();
Check location of : dtMasterDetailBlock.setInitialSelection();
Ashwani Kr Sharma
Previous Topic:Validation Order
Next Topic:Unable to retrieve the modified cell value in the Table Viewer
Current Time: Sat Jul 26 21:34:14 EDT 2025
Powered by FUDForum. Page generated in 0.05665 seconds
