Home » Modeling » TMF (Xtext) » A rule that consumes everything until certain char/string?
A rule that consumes everything until certain char/string? [message #712810] Sun, 07 August 2011 15:31 Go to next message
I was wondering if one could create a parser rule that allocates all characters up to a certain character or a certain string to a variable??
I was trying to do that with the '.' operator but if you loop this, you obviously consume everything.
Here's what I tried so far:
Form :
	'(' name=ANY_OTHERS ')';
terminal ANY_OTHERS :
	(ANY_OTHER)*;
Of course I would like to do something like:
name=ID
But in my case there can occur special characters which are not met by the terminal ID rule.
So I want to allocate anything to 'name' until a ')' occurs.
Has somebody an idea??
Regards, Robin
[Updated on: Sun, 07 August 2011 15:31] by Moderator
(no subject) [message #712845 is a reply to message #712810] Sun, 07 August 2011 16:10 Go to previous messageGo to next message
How about:
Form : '(' name = (ID|STRING|INT|ANY_OTHER)* ')' ;
If you also need to be able to have keywords and punctuation included,
you need to list them as well.
If you need white space, you need to unhide WS:
Form hidden(ML_COMMENT, SL_COMMENT) : name = (ID | STRING | INT |
ANY_OTHER | WS)* ;
Remember - ANY_OTHER is a token for things that are non of the other
tokens (keywords, punctuation, terminals).
Hope that helps.
- henrik
On 8/7/11 9:31 PM, Robin wrote:
> Form :
> (ANY_OTHER)*;
> Of course I would like to do something like: name=ID
> Regards, Michael
Re: (no subject) [message #713708 is a reply to message #712845] Mon, 08 August 2011 17:01 Go to previous messageGo to next message
Thanks, Henrik! That's a good idea. But I get an error saying
Cannot find type for 'ID | STRING | INT | ANY_OTHER'.
Also, I don't know if that will work eventually. Because at that position really ANY character can occur.
I thought maybe I could define a unicode range:
terminal ANY_EXCEPT_CLOSING_PARENTHESIS :
	( '\u0000'..'\u0028')* | ('\u0030'..'\uFFFF')*;
But this won't work either. :/ What am I doing wrong?
Regards, Robin
Re: (no subject) [message #713732 is a reply to message #713708] Mon, 08 August 2011 18:56 Go to previous messageGo to next message
Need to see your entire grammar - or at least all terminals in the order
they are stated to give better advice.
> Quote:
Maybe you need to put it in a separate rule. Do they have different
types declared?
It is best if the terminals all return string. If you want conversion,
write a separate rule that converts to the wanted type e.g. IntLiteral.
I think Xtext switches to string type automatically if a literal is used
in a data rule, but maybe if not used directly in an assignment.
So, try:
Form : name = FlexibleName ;
FlexibleName : (ID | STRING | INT | ANY_OTHER)* ;
Including a closing parenthesis?
> a unicode range:
> Regards, Robin
Are you on Xtext 1.0 ? I think unicode and ranges are supported in 2.0.
Still with ANY_OTHER : . ; you will get anything that is not matched by
any other rule, which basically means all unicode characters (except
possibly 0, which I am not sure about).
Remember - the ANY rule at the end can only match what preceding rules
have not matched. The lexer is a cookie cutter that operates without
knowledge about the grammar - just because a rule seems to be "calling"
a terminal rule does not mean that only that rule is considered - at
that point, the lexer has already done its work - the grammar gets a
stream of tokens from the lexer (i.e. 'terminals').
Thus - there is no difference if you use ANY_OTHER : '.'; or define a
character range that matches all possible characters. Since you have to
place this terminal last (or the *only* token your grammar will ever see
is your ANY_OTHER :) ).
- henrik
Re: (no subject) [message #713836 is a reply to message #713732] Tue, 09 August 2011 03:08 Go to previous messageGo to next message
Thank you so much, Henrik. It works now! Smile Though I am not sure how. Very Happy
I finally used:
Form :
	'(' name=FlexibleName '),';
FlexibleName :
I am wondering though why the ANY_OTHER not matches the '),' which is used in the Form rule. Hmmmm.... Is it because the Form rule is preceding as you mentioned? Does this mean then that the preceding rules create some kind of look-ahead mechanism for the Lexer?
I am using xtext 1.0.2 btw (sorry, forgot about versioning).
Regards, Robin
Re: (no subject) [message #713957 is a reply to message #713836] Tue, 09 August 2011 09:42 Go to previous messageGo to next message
ANY_OTHER matches only stuff not covered by any other terminal rule or keyword. '(' is a keyword in your Form rule.
Alex
Re: (no subject) [message #713993 is a reply to message #713836] Tue, 09 August 2011 09:41 Go to previous messageGo to next message
A suggestion, although The use of ")," works you probably want to have
')' ',' to enable whitespace, comments between them.
You also want to use hidden() on the FlexibleName to prevent spaces and
comments to be intermixed with the ID | STRING .... You don't need it on
Form, as the FlexibleName does not contain spaces or comments as it is
now defined.
Regarding tokens - *everything* you declare as keywords and punctuation
are delivered as separate tokens. If you need them anywhere you have to
specify them - or put differently, ANY_OTHER will never contain the
other tokens ('(' ')' '),' in this example).
If you use a bunch of punctuation and keywords in your grammar you can
do something like:
KEYWORDS : "if" | "else" | "while" | ... ;
PUNCTUATION : '.' | ',' | '-' | '_' ... ;
FlexibleName hidden() : PUNCTUATION | KEYWORDS | ID | STRING | ... ;
Remember, the Lexer is a scout sent out to report what animals are
walking towards the camp. Given only the terminal rules, the scout
reports "I see 'a duck', 'a bear', 'a tiger', ..."
- henrik
On 8/9/11 9:08 AM, Robin wrote:
> Thank you so much, Henrik. It works now! :) Though I am not sure how. :d
> I finally used:
> Form :
> FlexibleName :
> Regards, Robin
Re: A rule that consumes everything until certain char/string? [message #714006 is a reply to message #712810] Tue, 09 August 2011 11:08 Go to previous message
@Alexander, @ Henrik: thanks so much for pointing all that stuff out. Smile
Still a bit unsure of everything, but things are getting clearer... But I think I will have to do some more threats when I hit more problems. Very Happy
Regards, Robin
[Updated on: Tue, 09 August 2011 11:08] by Moderator
Previous Topic:Migrating to xtext 2.0
Next Topic:How to find files paths/names in project running with Xtend
Current Time: Sun Jul 27 02:28:51 EDT 2025
Powered by FUDForum. Page generated in 0.09226 seconds
