Home » Eclipse Projects » EclipseLink » H2 Table Creation on glassfish startup(How can I get Eclipselink to create Tables for an in memory db everytime the container is started)
H2 Table Creation on glassfish startup [message #713445] Mon, 08 August 2011 09:34 Go to next message
Java 1.6b24
Eclipselink 2.2.0.v20110202-r8913
Glassfish 3.1
I am doing some testing using H2 under Glassfish with Eclipselink as the peristence provider.
When I deploy a new EAR with a new Persistence Unit Eclipselink creates the tables in my H2 Database. However when I restart glassfish without redeploying the app, the new tables are not created and the app fails with exceptions such as
org.h2.jdbc.JdbcSQLException: Table "LAZYSINGLETON" not found; SQL statement:
SELECT ID, LASTMAPINSTANCE, LASTSETINSTANCE, VERSION, MAPITEMS_ID, SETITEMS_ID FROM LAZYSINGLETON WHERE (ID = ?) [42102-154]
My peristence.xml is as follows;
<persistence-unit name="Experiment8memPU" transaction-type="JTA">
<provider>org.eclipse.persistence.jpa.PersistenceProvider</provider>
<jta-data-source>Experiment8DBmem</jta-data-source>
<class>uk.co.his.experiment8.h2model.MapItem</class>
<class>uk.co.his.experiment8.h2model.SetItem</class>
<class>uk.co.his.experiment8.h2model.Singleton</class>
<class>uk.co.his.experiment8.h2model.lazy.LazyMapItem</class>
<class>uk.co.his.experiment8.h2model.lazy.LazyMap</class>
<class>uk.co.his.experiment8.h2model.lazy.LazySetItem</class>
<class>uk.co.his.experiment8.h2model.lazy.LazySet</class>
<class>uk.co.his.experiment8.h2model.lazy.LazySingleton</class>
<properties>
<property name="eclipselink.target-database" value="org.eclipse.persistence.platform.database.H2Platform"/>
<property name="javax.persistence.jdbc.url" value="jdbc:h2:mem:Experiment8DBmem"/>
<property name="eclipselink.ddl-generation" value="create-tables"/>
</properties>
</persistence-unit>
I have created the H2 DataSource using a glassfish-resource file ...
<jdbc-resource jndi-name="Experiment8DBmem" enabled="true" object-type="user" pool-name="Experiment8DBmemPool" />
<jdbc-connection-pool
datasource-classname="org.h2.jdbcx.JdbcDataSource"
res-type="javax.sql.DataSource">
<property name="User" value="admin" />
<property name="Password" value="admin" />
<property name="URL" value="jdbc:h2:mem:Experiment8DBmem" />
<property name="driverClass" value="org.h2.Driver" />
<property name="eclipselink.target-database" value="org.eclipse.persistence.platform.database.H2Platform /">
</jdbc-connection-pool>
Re: H2 Table Creation on glassfish startup [message #713510 is a reply to message #713445] Mon, 08 August 2011 10:53 Go to previous messageGo to next message
Will cause the tables to be recreated when the persistence unit is first accessed. Glassfish is probably doing something odd, and changing this property. Glassfish does do some things with DDL to try to handle DDL changes between deployments.
Re: H2 Table Creation on glassfish startup [message #713620 is a reply to message #713510] Mon, 08 August 2011 13:05 Go to previous messageGo to next message
Could I use a customizer to force this?
Re: H2 Table Creation on glassfish startup [message #714830 is a reply to message #713620] Thu, 11 August 2011 11:07 Go to previous message
I would check with the Glassfish community to see what they are doing first.
You cannot affect this property in a SessionCustomizer, but you could force table creation in a customizer thorugh using the DefaultTableGenerator directly.
Previous Topic:problems with historical sessions combined with @Version
Next Topic:TYPE() fails in projection query result: EclipseLink ConversionException
Current Time: Sat Jul 26 06:50:50 EDT 2025
Powered by FUDForum. Page generated in 0.07313 seconds
