Home » Archived » Sapphire » Element with Default Value(Automatic Creation of Elements with Default Values)
Element with Default Value [message #711806] Sat, 06 August 2011 13:13 Go to next message
I added the Default value annotation for a Property and i see the radio buttons appearing for it and default value being selected, but in my XML model i dont see the element created though i gave the @Required and @MustExist annotation. Unless and until i click on the element it does no create the element
Is there any way for adding the element tag automatically and populating it with DEFAULT value.
~Kamesh
Re: Element with Default Value [message #713606 is a reply to message #711806] Mon, 08 August 2011 12:36 Go to previous messageGo to next message
The @DefaultValue, @Required and @MustExist annotations do not operate at the level of XML binding.
@DefaultValue - Specifies the property value if a null was read from the underlying store (XML file, etc.).
@Required - Specifies that it should be a validation error if the property value is null. Does not make sense in conjunction with @DefaultValue.
@MustExist - Used with properties that name an external resource such as a file or a Java type to signify that the referenced entity has to exist or it's a validation error.
Getting back to your scenario, there are no declarative facilities to make sure that new elements are created with pre-populated content, but you can achieve this by implementing a custom binding for your list property. See @CustomXmlListBinding, StandardXmlListBindingImpl (the addUnderlyingObject method in particular).
- Konstantin
Re: Element with Default Value [message #713781 is a reply to message #713606] Mon, 08 August 2011 23:36 Go to previous messageGo to next message
Thanks for the info Konstantin, I have implemented a class DefaultXmlBinding following StandardXmlListBindingImpl for this purpose. I feel that we can add an Annotation @Mandatory and make this implementation there. Right now this supported only for Non-list types, may be we could extend it for other types too.
Attaching the code here so that it might be useful for some one.
~Kamesh
Re: Element with Default Value [message #714028 is a reply to message #713781] Tue, 09 August 2011 12:21 Go to previous messageGo to next message
I am certainly open to devising a way to incorporate this scenario into the framework. Go ahead an open an enhancement request and we can discuss this further there.
BTW, in your custom binding implementation, you are modifying the DOM tree during a read, which you shouldn't be doing. Applying the initial values should happen in the createUnderlyingObject method.
- Konstantin
Re: Element with Default Value [message #714038 is a reply to message #714028] Tue, 09 August 2011 12:37 Go to previous message
The bug is opened here https://bugs.eclipse.org/bugs/show_bug.cgi?id=354276
Previous Topic:Good idea, but ...
Next Topic:Content Assist
Current Time: Sun Jul 27 10:03:04 EDT 2025
Powered by FUDForum. Page generated in 0.07401 seconds
