| JDK API [message #71189] | Tue, 01 July 2003 18:44  |  |
| Eclipse User  |  |  |  |  | Originally posted by: haricharanm.hotmail.com
 Hi!
 I was trying to find a way to add Java API to Eclipse. I couldn't do that.
 I wonder if anyone could help me add J2SDK1.4 API to Eclipse so that I can
 get online help regarding packages, classes, and methods to be used in my
 code.
 Thankyou
 Haricharan M.
 Toronto.
| Re: JDK API [message #71327 is a reply to message #71189] | Wed, 02 July 2003 03:32  |  |
| Eclipse User  |  |  |  |  | Originally posted by: tom.eicher.gmx.ch.nodomain
 If you want to get the class library javadoc to display, there are two
 different concerns:
 1. Make sure you have the source along with the JRE you are using (will get
 autodetected when you install a JRE, or if added later, you can attach the
 source in the project's properties, on the Java Build Path page, by adding
 the source.zip to the rt.jar library.)
 You will now be able to seamlessly browse from your own code to JRE codea
 and get source and javadoc hovers when you point the mouse cursor over a
 method or class name.
 2. Define the javadoc location for the JRE
 In the Preferences, got to Java->Installed JREs. For your JRE, define the
 javadoc location to be the location where you would normally browse java API
 javadoc.
 You can now press use "Navigate->Show external javadoc" when the system
 caret is in a method and get the html javadoc for it to open in a browser.
 -tom
 "Haricharan Maramraj" <haricharanm@hotmail.com> wrote in message
 news:bdt2sp$7ct$1@rogue.oti.com...
 > Hi!
 > code.
 > Thankyou
 > Regards
 > Haricharan M.
 > Toronto.
FUDForum. Page generated in 0.06327 seconds
