(no subject) [message #706747] |
Sun, 31 July 2011 16:48  |
Originally posted by: rbenjamin
NPE when clicking "Finish" using either a custom ODA source.
This can be reproduced simply by creating the two ODA sample/wizard
plugins, fixing the driver package reference, and clciking finish.
Ideas?
Thanks!
Roy
!SESSION 2011-07-31 13:40:05.331
eclipse.buildId=unknown
java.version=1.6.0_13
Framework arguments: -product org.eclipse.platform.ide
Command-line arguments: -product org.eclipse.platform.ide -data
H:\Cassandra3/../runtime-EclipseApplication -dev
file:H:/Cassandra3/.metadata/.plugins/org.eclipse.pde.core/Eclipse
Application/dev.properties -os win32 -ws win32 -arch x86 -consoleLog -clean
!ENTRY org.eclipse.equinox.registry 2 0 2011-07-31 13:40:09.159
!MESSAGE The extensions and extension-points from the bundle
"org.eclipse.team.cvs.ssh" are ignored. The bundle is not marked as
singleton.
!ENTRY org.eclipse.emf.ecore 2 0 2011-07-31 13:40:13.800
!MESSAGE Both 'org.eclipse.gmf.bridge.trace' and
'org.eclipse.xpand.incremental' register an extension parser for 'trace'
log4j:WARN No appenders could be found for logger
(org.apache.cassandra.cql.jdbc.CassandraDriver).
log4j:WARN Please initialize the log4j system properly.
log4j:WARN See http://logging.apache.org/log4j/1.2/faq.html#noconfig for
more info.
!ENTRY org.eclipse.ui 4 0 2011-07-31 13:42:31.659
!MESSAGE Unhandled event loop exception
!STACK 0
at
org.eclipse.birt.report.designer.data.ui.dataset.DataSetBasePage.createDataSetODAV3(DataSetBasePage.java:902)
at
org.eclipse.birt.report.designer.data.ui.dataset.DataSetBasePage.createSelectedDataSet(DataSetBasePage.java:861)
at
org.eclipse.birt.report.designer.data.ui.dataset.DefaultDataSetWizard.performFinish(DefaultDataSetWizard.java:84)
at
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDialog.java:811)
at
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDialog.java:430)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.java:624)
at
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:234)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3657)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at
org.eclipse.birt.report.designer.data.ui.actions.NewDataSetAction.createNewDataSet(NewDataSetAction.java:193)
at
org.eclipse.birt.report.designer.data.ui.actions.NewDataSetAction.run(NewDataSetAction.java:181)
at org.eclipse.jface.action.Action.runWithEvent(Action.java:498)
at
org.eclipse.jface.action.ActionContributionItem.handleWidgetSelection(ActionContributionItem.java:584)
at
org.eclipse.jface.action.ActionContributionItem.access$2(ActionContributionItem.java:501)
at
org.eclipse.jface.action.ActionContributionItem$5.handleEvent(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2640)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2604)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2438)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:671)
at
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
at
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:664)
at
org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:115)
at
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
at
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at
sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
(no subject) [message #712800 is a reply to message #707368] |
Sun, 07 August 2011 15:03   |
It's working now. I did it the old fashioned way, I incrementally
copied my code into your working example. Someday I'll go back and
figure out what was wrong to begin with.
Roy
On 8/1/2011 7:52 AM, Jason Weathersby wrote:
> When you build the designer oda make sure you check the box that states
> that this plugin will contribute to the ui. And when you build the
> runtime oda make sure to un-check the same check box. If you debug the
> oda through eclipse make sure you have the following argument in the
> debug configuration.
> -XX:MaxPermSize=256M
> Attached is an example of both projects created with Indigo.
> Jason
>> Ideas?
>> Thanks!
>> Roy
>> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
>> -clean
>> singleton.
>> more info.
>> !STACK 0
>> java.lang.NullPointerException
>> at
>> at
>> at
>> at
>> at
>> at
>> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
>> at
>> at
>> at
>> at
>> at
>> at
>> at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
>> at
>> at
>> at java.lang.reflect.Method.invoke(Method.java:597)
(no subject) [message #713644 is a reply to message #712800] |
Mon, 08 August 2011 13:27  |
Thanks for the update. If you locate how you fixed it please post it.
Jason
On 8/7/2011 3:03 PM, rbenjamin wrote:
> It's working now. I did it the old fashioned way, I incrementally copied
> my code into your working example. Someday I'll go back and figure out
> Thanks
> Roy
>> Jason
>>> Ideas?
>>> Thanks!
>>> Roy
>>> -clean
>>> singleton.
>>> more info.
>>> !STACK 0
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
FUDForum. Page generated in 0.05023 seconds
