Home » Modeling » TMF (Xtext) » How do I use my language
How do I use my language [message #711896] Sat, 06 August 2011 15:42 Go to next message
I'm trying to use Xtext to write a simple scripting language that defines functions that calculate a value. I think I understand the basics of defining the grammar for the language and generating the lexer/parser/etc. Now I'm trying to figure out how to use the language at run time to process the functions and calculate the values.
I'm expecting that I need to initialize the system and pass a file/string containing the script statements to something that will parse the script. I then need to interact with the parsed data to pull out the statements and process them. It isn't obvious from the documentation how this is done. Is there an example somewhere that shows how to actually use your language after you have created it?
Re: How do I use my language [message #711907 is a reply to message #711896] Sat, 06 August 2011 16:06 Go to previous messageGo to next message
there are several possibilities to process the models. basically (code/text) generation or interpretation.
sadly some of the docs on this seem to be lost in the Xtext 2.0 docs.
(1) writing a code generator using Xtend2, Xpand, Acceleo or any other EMF capable generator technology. In the domain model example you'll find an example for this. the docs mention this too. http://www.eclipse.org/Xtext/documentation/2_0_0/040-first-code-generator.php
(2) writing an interpreter (reading the model and processing it)
Details depend on if you want to do this standalone or live.
In the Xtext 1.0 docs there was a hint on standalone. this should still work. http://www.eclipse.org/Xtext/documentation/1_0_1/xtext.html#processing_Xtext_models
Markus built a framework for this http://code.google.com/a/eclipselabs.org/p/xtext-typesystem. don't know if this works with Xtext 2.0 too.
The Xtext 1.0 Arithmetics example might be a look worth for a live interpreter too.
In both casing the task is basically:
(1) read the model
(2) walk over the model (a java object tree) and process some output.
To give further hints please tell if you want to execute the stuff standalone / action triggered / save triggered etc
and what kind of output you want to produce.
~Christian
Re: How do I use my language [message #711916 is a reply to message #711907] Sat, 06 August 2011 16:28 Go to previous messageGo to next message
The Eclipse b3 language has a quite comprehensive interpreter and type
inference that you may want to take a look at as an example.
- henrik
On 8/6/11 10:06 PM, Christian Dietrich wrote:
> (2) writing an interpreter (reading the model and processing it) Details
> work.
> interpreter too.
> (1) read the model
> ~Christian
Re: How do I use my language [message #712132 is a reply to message #711916] Sat, 06 August 2011 23:09 Go to previous messageGo to next message
> Regards
> - henrik
I'm not looking for a build managment system which is what b3 appears to
be from the description. I need to be able to process the language I
develop.
>> Hi,
>> work.
>> interpreter too.
>> (1) read the model
>> ~Christian
Re: How do I use my language [message #712139 is a reply to message #711907] Sat, 06 August 2011 23:19 Go to previous messageGo to next message
On 08/06/2011 03:06 PM, Christian Dietrich wrote:
> work.
Hint is an appropriate description of the link. It doesn't really show
you how you can process the language, it basically says that you can and
there a optional properties that you can use to deal with the
processing. The Xtext project appears to really be lacking an example
of actually processing a language and doing something with it. I'm not
a language expert nor a model expert. Without an example, I'm not sure
Xtext will be useful to my needs.
> interpreter too.
> (1) read the model
I guess I want to execute the stuff standalone. I would like to develop
a calculation engine. The language would be used to define calculations
for financial values. A given calculation would be defined in a
"source" file using the DSL I'm developing. The engine would need to
read the calculation source files and interpret them. The calculations
would produce a result that would be published out.
> ~Christian
Re: How do I use my language [message #712427 is a reply to message #712139] Sun, 07 August 2011 04:29 Go to previous messageGo to next message
i don't get it: hendrik pointed to b3 as an example for an interpreter so have a look at b3s sourcecode.
i still do not understand what problems ou have with processing since it is just instances of java classes
you walk over. can you be a bit more elaborating why this makes problems to you
or ask questions on concrete problems?
~Christian
Re: How do I use my language [message #712442 is a reply to message #712427] Sun, 07 August 2011 04:49 Go to previous messageGo to next message
and just do complete this: here is a "very fancy" interpreter for the Xtexts Hello World Greeting DSL
import org.eclipse.emf.common.util.URI;
import org.eclipse.emf.ecore.resource.Resource;
import org.eclipse.emf.ecore.resource.ResourceSet;
import org.xtext.example.mydsl.MyDslStandaloneSetup;
import org.xtext.example.mydsl.myDsl.Greeting;
import org.xtext.example.mydsl.myDsl.Model;
import com.google.inject.Injector;
public class Interpreter {
		Injector injector = new MyDslStandaloneSetup().createInjectorAndDoEMFRegistration();
		ResourceSet rs = injector.getInstance(ResourceSet.class);
		Resource r = rs.getResource(URI.createURI("src/model.mydsl"), true);
		Model m = (Model) r.getContents().get(0);
		for (Greeting g : m.getGreetings()) {
			System.out.println("Hello, " + g.getName());
~Christian
Re: How do I use my language [message #712583 is a reply to message #712132] Sun, 07 August 2011 09:02 Go to previous messageGo to next message
> develop.
The tip was that if you want to write an interpreter you could look at
the *source code* of b3, not run it.
- henrik
Re: How do I use my language [message #712802 is a reply to message #712442] Sun, 07 August 2011 14:41 Go to previous messageGo to next message
On 08/07/2011 03:49 AM, Christian Dietrich wrote:
> public static void main(String[] args) {
> ~Christian
Thanks, I think I'm starting to get it now. I think part of the problem
was not realizing that the classes that you need to process the language
are created when you generate the grammar. I kept thinking that you
needed to call Xtext provided classes to access the AST. This is where
the confusion came from.
I'm still not completely sure about the relationship between the src,
src-gen, and xtend-gen directories in the projects. A better
explanation of what classes go into each location and in what cases you
need to use them would be helpful.
Re: How do I use my language [message #713173 is a reply to message #712802] Mon, 08 August 2011 03:20 Go to previous message
src: Sources that are ment to be manually maintained
src-gen: Generated sources from Xtext. Do not touch. They will be regenerated when you start the generator workflow.
xtend-gen: Generated sources from .xtend files. Do not touch. They will be regenerated when you save an .xtend file.
Xtext follows the Generation Gap Pattern. You can read about it on the web. Short: Strict seperation of manual, generated and generic code.
~Karsten
Previous Topic:[XTEND] Standalone compiler
Next Topic:[Question] Xtext 2.0 / Xtend2 Generator Development
Current Time: Sun Jul 27 06:37:35 EDT 2025
Powered by FUDForum. Page generated in 0.04836 seconds
