Home » Modeling » Graphiti » Anchors or nested shapes?
Anchors or nested shapes? [message #710859] Fri, 05 August 2011 09:52 Go to next message
I'm a newbie at Graphiti, I'm designing some editor that has some similarities with this GMF tutorial example. Basically, my nodes are functions with (distinct, named) inputs, and outputs, each connections links an output to an input. I'm trying to decide between two approaches:
1. each individual input/output is an anchor (fix point) of the function node (as in most graphiti examples)
2. each individual input/output is a nested object/shape of the parent node (as in that gmf tutorial)
I will have many different functions (they are not necessarily known at compile time) - but once a node is created, it's function "signature" (inputs and outputs) is fixed. Perhaps some inputs can become hidden (by user action or by the domain).
I'm (slightly, hesitantly) tending to approach 2, but I didn't see any Graphiti example of that approach, and I wonder if that is feasible or advisable.
Any opinions?
[Updated on: Fri, 05 August 2011 09:56] by Moderator
Re: Anchors or nested shapes? [message #713903 is a reply to message #710859] Tue, 09 August 2011 06:44 Go to previous message
In my opinion the 2nd approach is the better one. You have more possibilities for the graphical representation. For this nested shapes you should use chopbox anchors.
BR,
Matthias
Previous Topic:Workflow Editor with Graphiti
Next Topic:link from container and child shape to the same object?
Current Time: Thu Jul 24 21:58:46 EDT 2025
Powered by FUDForum. Page generated in 0.07216 seconds
