Home » Modeling » OCL » Collection beginner question
Collection beginner question [message #71034] Thu, 28 May 2009 09:22 Go to next message
Hey all,
the types OrderedSet and Sequence are orderede types. But which kind of
ordering relation is defined on them? And how to define such a relation?
Timothy
Re: Collection beginner question [message #71056 is a reply to message #71034] Thu, 28 May 2009 14:39 Go to previous messageGo to next message
Hi Tomothy,
I'm not sure what you mean "kind of ordering relation". They are
different (not-related) types after all. You may use specific operations
(defined in the standard library) to obtain an OrderedSet from a
Sequence, and viceversa.
The difference between these types basically is that in a Sequence you
can have different occurrences of the same object, which is not valid in
an OrderedSet. For example, look at the following valid expression
Sequence {1, 1 , 2, 3}->asOrderedSet() = OrderedSet {1, 2, 3}
They are both ordered collections (you could access the object in the
first position of the collection), but you can't have multiple
occurrences of the same object (the integer '1', in this case) in the
OrderedSet.
Adolfo.
Timothy Marc escribió:
> Hey all,
> Thanks
> Timothy
Re: Collection beginner question [message #71076 is a reply to message #71056] Thu, 28 May 2009 15:04 Go to previous messageGo to next message
Okay,
let me precise my question. For example:
context Class:op(arr:OrderedSet(Class2))
The parameter in the uml model is specified as
Parameter arr (in), ordered, unique, upperBound *
But, where can i define the kind of the ordering??? For me, it looks
like this is more or less an information, which is only relevant for the
code generation.
hope, my question is now more clear?
thx
timothy
Adolfo Sánchez-Barbudo Herrera schrieb:
> Hi Tomothy,
> OrderedSet.
> Cheers,
> Adolfo.
>> Hey all,
>> of ordering relation is defined on them? And how to define such a
>> relation?
>> Thanks
>> Timothy
Re: Collection beginner question [message #71095 is a reply to message #71076] Thu, 28 May 2009 16:23 Go to previous messageGo to next message
Hi Timothy,
Look at the following table. I guess it could help you...
Collection Ordered Unique
Set false true
OrderedSet true true
Sequence true false
Bag false false
The unique qualifier is the key in your case to distinguish between
OrderedSet and Sequence.
As I said, the OrderedSet doesn't allow multiple occurrences in the
collection, which is modelled in your case with unique=true.
Adolfo.
> Okay,
> code generation.
> thx
> timothy
>> Hi Tomothy,
>> operations (defined in the standard library) to obtain an OrderedSet
>> from a Sequence, and viceversa.
>> in an OrderedSet. For example, look at the following valid expression
>> OrderedSet.
>> Cheers,
>> Adolfo.
>>> Hey all,
>>> relation?
>>> Thanks
>>> Timothy
Re: Collection beginner question [message #71115 is a reply to message #71095] Fri, 29 May 2009 05:21 Go to previous messageGo to next message
Originally posted by: Alexander.Igdalov.borland.com
Hi Timothy and Adolfo,
I suppose Timothy wants to find out by which relation are the elements
ordered. IOW, where the comparator is=))
Elements in OrderedSet and Sequence are ordered by the initial order
(sorry for tautology) in which they were put in the collection. Since
OCL collections are immutable their order is set on collection
instantiation. It means that:
Sequence {80, 2, 100, 55} would be an (ordered) sequence in which the
first element is 80, the second is 2 and so forth. Elements themselves
are not compared.
If you want to change the order of the elements in a collection you need
to create another re-ordered collection with the same elements. In some
cases for sorting in ascending order you can use sortedBy() operation.
For instance,
eClasses->sortedBy(name) -- given that eClasses in a collection of EClass'es
Note, that in this case the elements must be comparable. In terms of UML
the type of the body expression must have the < operation defined. The <
operation must return a Boolean value and must be transitive (i.e., if a
< b and b < c then a < c). This is true for collections of primitive
types, for instance.
HTH,
Alex.
Adolfo Sánchez-Barbudo Herrera wrote:
> Hi Timothy,
> Set false true
> Sequence true false
> Bag false false
> Cheers,
> Adolfo.
>> Okay,
>> the code generation.
>> thx
>> timothy
>>> Hi Tomothy,
>>> you can have different occurrences of the same object, which is not
>>> valid in an OrderedSet. For example, look at the following valid
>>> expression
>>> OrderedSet.
>>> Cheers,
>>> Adolfo.
>>>> Hey all,
>>>> relation?
>>>> Thanks
>>>> Timothy
Re: Collection beginner question [message #71135 is a reply to message #71115] Fri, 29 May 2009 06:40 Go to previous messageGo to next message
Ouch,
I've realized that
1. the example which I chose, may have confused the reader instead of
helping ;P
2. I didn't obviously catch the question.
As I explained and alex remarked, the term "ordered" just indicates that
the elements have "an order or position" in the collection, and
therefore you can access the elements by its position in it (you could
use the "at" operator).
I agree with the whole explanation of Alex. Thank you for catching the
problem and for explaining it;)
Adolfo.
> are not compared.
> For instance,
> EClass'es
> HTH,
> Alex.
>> Hi Timothy,
>> Set false true
>> Sequence true false
>> Bag false false
>> Cheers,
>> Adolfo.
>>> Okay,
>>> thx
>>> timothy
>>>> Hi Tomothy,
>>>> expression
>>>> the first position of the collection), but you can't have multiple
>>>> the OrderedSet.
>>>> Cheers,
>>>> Adolfo.
>>>>> Hey all,
>>>>> kind of ordering relation is defined on them? And how to define
>>>>> such a relation?
>>>>> Thanks
>>>>> Timothy
Re: Collection beginner question [message #71155 is a reply to message #71135] Fri, 29 May 2009 08:56 Go to previous messageGo to next message
> Ouch,
> I've realized that
> helping ;P
NP:) Let's see whether it was what Timothy wanted.
> Cheers,
> Adolfo.
>> themselves are not compared.
>> need to create another re-ordered collection with the same elements.
>> In some cases for sorting in ascending order you can use sortedBy()
>> operation. For instance,
>> EClass'es
>> UML the type of the body expression must have the < operation defined.
>> The < operation must return a Boolean value and must be transitive
>> (i.e., if a < b and b < c then a < c). This is true for collections of
>> primitive types, for instance.
>> HTH,
>> Alex.
>>> Hi Timothy,
>>> Set false true
>>> Sequence true false
>>> Bag false false
>>> Cheers,
>>> Adolfo.
>>>> Okay,
>>>> thx
>>>> timothy
>>>>> Hi Tomothy,
>>>>> OrderedSet from a Sequence, and viceversa.
>>>>> expression
>>>>> the OrderedSet.
>>>>> Cheers,
>>>>> Adolfo.
>>>>>> Hey all,
>>>>>> such a relation?
>>>>>> Thanks
>>>>>> Timothy
Re: Collection beginner question [message #71194 is a reply to message #71155] Tue, 02 June 2009 16:36 Go to previous message
Alex,
yes, this was exactly the kind of hint, i was looking for :-) Thanks a
lot for that explanation.
And also, thanks to you Adolfo :-)
Regards Timothy
>> Ouch,
>> I've realized that
>> helping ;P
>> that the elements have "an order or position" in the collection, and
>> Cheers,
>> Adolfo.
>>> elements ordered. IOW, where the comparator is=))
>>> EClass'es
>>> defined. The < operation must return a Boolean value and must be
>>> transitive (i.e., if a < b and b < c then a < c). This is true for
>>> collections of primitive types, for instance.
>>> HTH,
>>> Alex.
>>>> Hi Timothy,
>>>> Set false true
>>>> Sequence true false
>>>> Bag false false
>>>> Cheers,
>>>> Adolfo.
>>>>> Okay,
>>>>> looks like this is more or less an information, which is only
>>>>> relevant for the code generation.
>>>>> thx
>>>>> timothy
>>>>>> Hi Tomothy,
>>>>>> not valid in an OrderedSet. For example, look at the following
>>>>>> valid expression
>>>>>> the OrderedSet.
>>>>>> Cheers,
>>>>>> Adolfo.
>>>>>>> Hey all,
>>>>>>> such a relation?
>>>>>>> Thanks
>>>>>>> Timothy
Previous Topic:[Announce] MDT OCL 1.3.0RC3 is available
Next Topic:OCL for sequence diagram
Current Time: Mon Nov 03 03:47:24 EST 2025
Powered by FUDForum. Page generated in 0.12153 seconds
