UI artefacts after installing of features into buckminster [message #702643] |
Tue, 26 July 2011 11:50  |
Originally posted by: Ralf Zozmann
Hi @all,
currently i'm trying to update our build process from bucky 3.6 to the
Eclipse 3.7 based variant.
We are using buckminster also as host for some code generation tasks
while the build process. So i have to install additional features into
the headless buckminster (org.eclipse.buckminster.cmdline.product
1.4.0.v20110629-1242). All the headless features coming from the
buckminster sites seems to be ok (means
org.eclipse.buckminster.core.headless.feature,
org.eclipse.buckminster.subversive.headless.feature, ...).
But the simpelst additional feature i try to install does come with UI
bundles at the end. As example: Installing the 'org.eclipse.emf.common'
feature (via scipt using the buckminster 'install' command) will also
install org.eclipse.ui, org.eclipse,swt, org.eclipse.jface,....
Looking into the feature.xml and the dependencies for
'org.eclipse.emf.common' only 'org.eclipse.core.runtime' is requested.
Currently i have no idea why these bundles are materialized, but i have
trouble from the presence.
Can anybody help me to understand that phenomenon so i can work around?
Ralf
Re: UI artefacts after installing of features into buckminster [message #703113 is a reply to message #702643] |
Wed, 27 July 2011 02:55   |
Morning,
after some more investigation i doesn't longer believe that this is a
problem related to buckminster, but something wrong this the used update
sites. Using my example (installing feature org.eclipse.emf.common) from
yesterday:
If i install the feature from
http://download.eclipse.org/modeling/emf/updates/releases/ then all is
ok, but if i use the update site
http://download.eclipse.org/releases/indigo/ i got all the ui bundles as
result.
Strange! Mmhhh.. is this in any way related to the circular dependency
problem of JDT->UI, but in a different bundle (one more patch affecting
a normally headless plugin)?
Ralf
On 07/26/2011 05:50 PM, Ralf Zozmann wrote:
> Hi @all,
> Thanks
> Ralf
Re: UI artefacts after installing of features into buckminster [message #710709 is a reply to message #704580] |
Fri, 05 August 2011 05:59   |
Hi Thomas,
i have tested again to give you more informations...
Director version:
org.eclipse.equinox.p2.director.product_1.4.0.v20110505-0000.zip
Buckminster version:
org.eclipse.buckminster.site.eclipse.headless_1.4.0.v20110712-1350.zip
To install features without optional dependencies i have to mirror that
artefacts to a local repository and to install the feature from that
instead from our complete eclipse mirror. To do that i have to install
p2 related bundles for mirroring. So i install the
'org.eclipse.equinox.p2.extras.feature' from the 'equinox-SDK-3.7.zip'
into the buckminster installation. The Director installation i leave
untouched. As result: the unmodified Director may install the feature
org.eclipse.emf.common without problems, the Buckminster will fail.
A Buckminster without additional p2 bundles will also install the
feature without problem.
So the reason for the install problem seems to be the presence of
additional p2 bundles. Looking into the 'equinox-SDK-3.7.zip' i see only
the same versions for bundles also coming with Buckminster.
Ralf
PS: So i have currently no problem, there is no need to invest more time :-)
Am 28.07.2011 21:50, schrieb Thomas Hallgren:
> On 2011-07-28 13:51, Ralf Zozmann wrote:
>> Hi,
>> currently i'm testing a time-consuming/complex workaround: Download
>> (mirroring) the required additional features into a local US (without
>> any dependencies) and install them from there, so all the ui bundles are
>> suppressed. I have tested two variants:
>> a) install the feature using the buckminster 'install' command
>> b) install the feature using the director
>> The buckminster 'install' fails always with unresolved dependencies
>> (only from optionals!), but the director can install the feature bundles
>> without problem.
>> There seems to be a difference between buckminster and director
>> processing a feature installation?!
> Exactly what commands do you use, and what versions? The Buckminster
> install command is only a thin wrapper for the director. It's only
> motivation is backward compatibility. What it does is essentially adding
> the '.feature.group' suffix to the feature name. When you use the
> director you must remember to add that yourself.
> - thomas
Re: UI artefacts after installing of features into buckminster [message #710723 is a reply to message #710709] |
Fri, 05 August 2011 06:42   |
Hi Ralf,
This is interesting. Can you please try to install these extra p2
bundles into the director and see if it has the same negative impact there?
- thomas
On 2011-08-05 11:59, Ralf Zozmann wrote:
> Hi Thomas,
> Director version:
> Regards
> Ralf
>>> Hi,
>>> without problem.
>> - thomas
Re: UI artefacts after installing of features into buckminster [message #710841 is a reply to message #710723] |
Fri, 05 August 2011 09:14  |
Am 05.08.2011 12:42, schrieb Thomas Hallgren:
> Hi Ralf,
Installing the p2 feature into the director (using the director self)
gives me the follwing output, i think it was successful:
[director] Installing
org.eclipse.equinox.p2.extras.feature.feature.group
1.0.0.v20110519-7A4FD3DiVOManmZvpLOsnBhnPQM3.
[director] Artifact repository out of sync. Overwriting
......\director\plugins\org.eclipse.equinox.security.win32.x86_1.0.200.v20100503.jar
[director] Operation completed in 17047 ms.
Installing the feature org.eclipse.emf.common afterwards using the same
director with additional p2 bundles is simply successfully:
[director] Installing org.eclipse.emf.common.feature.group
2.7.0.v20110605-0747.
[director] Operation completed in 1500 ms.
Ralf
FUDForum. Page generated in 0.06845 seconds
