Home » Eclipse Projects » Nebula » [Grid] Smooth scrolling
[Grid] Smooth scrolling [message #710704] Fri, 05 August 2011 06:22 Go to next message
I'm using the Grid widget to show a number of image thumbnails, with some columns to edit information for each image. Each thumbnail is 200x150 in size.
However due to the height of each image (and depending on screen resolutions / other controls on screen) there is sometimes only space to show 3-4 rows on screen at once. This will usually result in scroll bars showing.
The annoyance in this case is that the top row is always shown as a complete cell. When scrolling, it jumps 3 cells (assuming this is based on Windows scroll settings), which can be a bit confusing when only 3-4 rows are able to be shown, as the entire screen will change.
I guess my usage of the Grid isn't all that common, and the SWT Table / Tree will always show the top row as complete too. Essentially the behaviour I'm after is similar to that of the Gallery, where scrolling is smooth, and the top of the control can be a partial image.
Does this sound possible? And does anyone have any hints where changes would be required? I've been looking within the Grid / Gallery source, but it's quite daunting with 10700 and 2600 lines of code respectively, plus supporting classes!
Daniel
Re: [Grid] Smooth scrolling [message #710730 is a reply to message #710704] Fri, 05 August 2011 06:50 Go to previous messageGo to next message
I guess you want the same feature one can turn on for column
setColumnScrolling().
So essentially you'll have to take a look how this implemented but it
looks like this is not really a trivial thing to change.
Tom
Am 05.08.11 12:22, schrieb Daniel MacDonald:
> 200x150 in size.
> showing.
> Daniel
Re: [Grid] Smooth scrolling [message #710743 is a reply to message #710730] Fri, 05 August 2011 07:14 Go to previous messageGo to next message
Thanks for the reply, Tom
I figured it wouldn't be too easy if it didn't already exist, but thanks for the pointer in the right direction.
Might be quite a nice feature for Grid v2...
Cheers
Daniel
Re: [Grid] Smooth scrolling [message #710752 is a reply to message #710704] Fri, 05 August 2011 07:28 Go to previous messageGo to next message
Hi Daniel,
You can apply the smooth scrolling of Gallery on most widgets.
See : http://eclipse.org/nebula/widgets/gallery/r_0_20110516/javadoc/org/eclipse/nebula/animation/ScrollingSmoother.html
But if the widget only allow do display complete cells like Grid, this will may look strange.
You have 2 options to implement what you describe :
- Change grid to support partial cell display
- Switch to gallery and implement a custom renderer. You'll have to add support for editable text field which are not supported currently (this will probably not be easy).
Re: [Grid] Smooth scrolling [message #710788 is a reply to message #710752] Fri, 05 August 2011 08:13 Go to previous messageGo to next message
Thanks for the reply, Nicolas
I hadn't thought of using the ScrollingSmoother for this, I remember playing around with it for the Gallery though.
As you suggest, it does look strange - using the BounceOut movement for example just causes a delay in the scrolling.
Switching to the Gallery sounds even trickier (I'm using lots of different types of cell editor for different columns, plus making use of column groups), so it looks like partial cell display will be the way to go
Daniel
Re: [Grid] Smooth scrolling [message #754403 is a reply to message #710788] Wed, 02 November 2011 08:57 Go to previous message
A workaround to obtain a similar looking partial cell scrolling functionality could be to place a Grid inside a ScrolledComposite (do not use the grid's scrolling mechanism and set the scrolled composite's minimum height to something very large so the scroll bar appears from the start around the grid).
Previous Topic:Module name required
Next Topic:Grid cell selection
Current Time: Wed Jul 23 14:52:50 EDT 2025
Powered by FUDForum. Page generated in 0.04001 seconds
