Validation Order [message #709791] |
Thu, 04 August 2011 06:01  |
Is there any way to handle validation order with jface databinding framework?
For now, it works due to binding order in the java class.
And even if i put binding to the last line, it works before some other bindings.
In my java code, i used AllRequiredValidator, so even one of required form fields are missing, it shows an error because of it is required and also it doesnt work in order.
For example.
Below are all required fields
Field 1
Field 2
Field 3
Field 4
Instead of field 1 must show required error, field 4 shows that it is required.
How can you handle this kind of problem?
I really need help or any other solution recommends.
Ercan CANLIER
FUDForum. Page generated in 0.05288 seconds
