Home » Modeling » Graphiti » dynamical CreateFeatures ?
dynamical CreateFeatures ? [message #710172] Thu, 04 August 2011 15:27 Go to next message
Motivation: in the Graphiti tutorial in the Help, the creation of each object (Eclass) corresponds to a (say) MyCreateFeature class, there is a single class, and a single instance of this class, and a single create icon in the palette; and the "name" of each create object is filled by the user in a creation popup. Suppose that, in addition to that, I wish to have some feature to create some set of Eclass objects with some predetermined names
I'd wish to avoid to code a separate CreateFeature class for each case.
I wonder, if, for example, I could add some "name" property to my MyCreateFeature class, and create several instances of this class to return them in my MyFeatureProvider.getCreateFeatures() , so that each instance would have a different behaviour. Would this be impossible, or convoluted?
In particular, it's not clear for me which is the contract of the IFeatureProvider.getCreateFeatures() method: when is this -internally- called? Only for the palette? Must this be in sync with the palette? Can I have several instances of the same class?
Another issue (more difficult, I guess) would be to make those instances dynamic; for what I see, the contents of the palette MyToolBehaviorProvider.getPalette() seems to be static, is that so?
[Updated on: Thu, 04 August 2011 15:29] by Moderator
Re: dynamical CreateFeatures ? [message #710222 is a reply to message #710172] Thu, 04 August 2011 16:40 Go to previous messageGo to next message
Hi Hernan,
the palette is build up in the DefaultToolBehaviorProvider.getPalette method. There is the access to the create features provided by the feature provider:
ICreateFeature[] createFeatures = featureProvider.getCreateFeatures();
for (ICreateFeature createFeature : createFeatures) {
   ObjectCreationToolEntry objectCreationToolEntry = new ObjectCreationToolEntry(createFeature.getCreateName(),
   createFeature.getCreateDescription(), createFeature.getCreateImageId(), createFeature.getCreateLargeImageId(), createFeature);
   compartmentEntry.addToolEntry(objectCreationToolEntry);
You can override that method in your own tool behavior provider to inject your parameterized create feature instances.
The call chain is
DiagramEditorInternal.refreshPalette()
-> GFPaletteRoot .updatePaletteEntries()
-> IToolBehaviorProvider.getPalette()
So you can get trigger the refresh of the palette by calling getDiagramEditor().refreshPalette(), as getDiagramEditor() is defined in AbstractFeature and so available in every feature class.
Cheers
Joerg
Re: dynamical CreateFeatures ? [message #710362 is a reply to message #710222] Thu, 04 August 2011 20:07 Go to previous message
Great, thanks.
Previous Topic:Connection onMouseOver?
Next Topic:Setting own file extension for Graphiti Diagram
Current Time: Sat Nov 01 06:51:09 EDT 2025
Powered by FUDForum. Page generated in 0.05680 seconds
