Home » Language IDEs » PHP Development Tools (PDT) » How to integrate Symfony2 to Eclipse
How to integrate Symfony2 to Eclipse [message #709906] Thu, 04 August 2011 09:16 Go to next message
did someone has experience with Symfony2 in elipse?
I've installed this plugin pulse00.github.com/Symfony-2-Eclipse-Plugin/ .
But I dont know how I can start a Symfony-Project in eclipse.
What did I have to configure?
Re: How to integrate Symfony2 to Eclipse [message #709957 is a reply to message #709906] Thu, 04 August 2011 10:25 Go to previous messageGo to next message
On 2011-08-04 15:16, y.uddin wrote:
What exactly support You need?
/dmc
Re: How to integrate Symfony2 to Eclipse [message #710563 is a reply to message #709957] Fri, 05 August 2011 02:49 Go to previous messageGo to next message
I dont know, how I can start a Symfony2-project in eclipse
and what I have to configure after plugin install.
Re: How to integrate Symfony2 to Eclipse [message #758402 is a reply to message #710563] Wed, 23 November 2011 01:57 Go to previous messageGo to next message
At the time of your writing the plugin did not have a new project wizard, so initializing a project as a proper symfony2 project was somewhat hidden. That should be straightforward now.
if you still got problems with the plugin, please report any issues you may encounter on the associated github.com project: https://github.com/pulse00/Symfony-2-Eclipse-Plugin/issues.
Re: How to integrate Symfony2 to Eclipse [message #759030 is a reply to message #758402] Fri, 25 November 2011 12:04 Go to previous messageGo to next message
Got problem to run symfony2 on Eclipse
I got Version: Helios Release
Build id: 20100617-1415
Is someone can share eclipse software folder working with Symfony2 ?
I try a lot of combinations, always get error...
I m fed up
Want autocompletion of Symfony on Remote host project
Thanks for your help
Bye
Re: How to integrate Symfony2 to Eclipse [message #759054 is a reply to message #759030] Fri, 25 November 2011 15:45 Go to previous message
Hi ibasaw,
please report any issues you have with the plugin as a github issue: https://github.com/pulse00/Symfony-2-Eclipse-Plugin/issues?sort=created&direction=desc&state=open
This is the main repository for the plugin where issues should be reported.
Previous Topic:xdebug: Unexpected termination of script
Next Topic:Zend debugger installation for PDT 2.2 fails
Current Time: Mon Jul 21 08:34:05 EDT 2025
Powered by FUDForum. Page generated in 0.31316 seconds
