Home » Modeling » GMF (Graphical Modeling Framework) » How to add a text panel to my diagram editor ?
How to add a text panel to my diagram editor ? [message #709750] Thu, 04 August 2011 04:59 Go to next message
Hi everyone !
I've got a diagram editor, with a class A.
This class A got a property B which is a String.
My problem is that this string may be huge, and won't fit in the default property editor.
I would like to add a new panel with a text area where i can edit B for the selected A, but i've no idea about how to do that.
I'm quite used to swing but rcp development is new for me.
Can someone help me ? GMF generate so many classes, i don't even know where to start searching.
Thanks a lot !
(no subject) [message #709901 is a reply to message #709750] Thu, 04 August 2011 09:04 Go to previous messageGo to next message
You could think about using EEF [1] to customize your property views,
Or you can also code your own property sheets for your diagram. In order
to do so, take a look at the generated plugin.xml and mimic the way GMF
generates your "Rules & Grid" sections and so on.
HTH,
[1] http://www.eclipse.org/modeling/emft/?project=eef
http://mickaelistria.wordpress.com
http://twitter.com/#!/mickaelistria
http://www.petalslink.com
Re: (no subject) [message #709956 is a reply to message #709901] Thu, 04 August 2011 10:23 Go to previous messageGo to next message
In the EMF genmodel, set "multiline" to true for the string property, then the default property sheet will contain a nice little multiline editor.
You could also install a modified open diagram policy so that on double click a text input is opened.
Re: How to add a text panel to my diagram editor ? [message #710397 is a reply to message #709750] Thu, 04 August 2011 21:06 Go to previous message
Thanks a lot !
That's exactly the help i needed
Previous Topic:Node Container
Next Topic:PNML & EzPetri
Current Time: Sat Jul 26 11:33:53 EDT 2025
Powered by FUDForum. Page generated in 0.05551 seconds
