From Model to Edit Part [message #708199] |
Tue, 02 August 2011 11:05  |
Hi there,
I've been mulling it over for a long time.
I know how to get Model Element from Edit Part :
EObject myObject = myEditPart.resolveSemanticElement();
Is there a way to get the Edit Part from the Model Element please ?
Nicolas
Re: From Model to Edit Part [message #708816 is a reply to message #708770] |
Wed, 03 August 2011 03:43   |
Hi Mickael, Andreas
Thanks for your replies.
Quote:The DiagramEditorUtil#openEditor returns a reference to your editor. Or you can
access the active editor like this:
IEditorPart myEditor = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().getActiveEditor();
Good idea, I didn't think about getting my editor instance by that way.
Quote:What is the need for that? Sure you can, but you can not access editparts since they will be created on editor open and disposed on editor close.
It means that my solution does not solve my initial problem:
UC1:
I want to create my diagram, create a small initial model, and finally open my diagram. Sure I can use DiagramEditorUtil#createInitialModel to add model elements to my diagram, but I don't know how to define the position and the size of my elements on diagram.
UC2:
As a general rule, I wish I could add semantic element with it graphical aspect anywhere, in a view for example, even if the diagram is closed. For example, I generate <model>Diagram width GMF, So I two files, the model file xxx.model and the diagram file xxx.model_diag. I release a button in a view, and a new model element is added in xxx.model with it graphical aspect in xxx.model_diag, so I could see it when I opened my diagram.
For that, I found some code using CreateViewAndElementRequest class but in order to adding an object in the diagram, I had to get the rootEditPart.
Obviously, using editpart is not the way to do this...
Quote:Hi,
Assuming that your "parentEditPart" contains the editPart which
represents the "targetModelElement" in one of its children or
grand-children, you can try the following line:
IGraphicalEditPart targetPart =
parentEditPart.findEditPart(parentEditPart, targetModelElement);
HTH,
That might be my previous problem : I did'nt know how to get "(parent|root)EditPart"
Thanks for your help,
Nicolas
Re: From Model to Edit Part [message #708886 is a reply to message #708816] |
Wed, 03 August 2011 04:58   |
Hi Nicolas,
UC1:
I did something similar in my open source project YAKINDU Statechart Tools. This code creates a semantic element (initialState) and adds some layout constraints to the view. Maybe this is a starting point for you.
//Create semantic element
Entry initialState = SGraphFactory.eINSTANCE.createEntry();
initialState.setKind(EntryKind.INITIAL);
//Create view for semantic element
Node initialStateView = ViewService.createNode(
parentView, initialState,
SemanticHints.ENTRY, DiagramActivator.DIAGRAM_PREFERENCES_HINT);
//Set inital bounds for the view
Bounds bounds = NotationFactory.eINSTANCE.createBounds();
bounds.setX(70);
bounds.setY(20);
initialStateView.setLayoutConstraint(bounds);
UC2:
Basically, the approach of UC1 works for that Usecase, too. You can simply load the resource and modify it like this.
FUDForum. Page generated in 0.30124 seconds
