Home » Archived » BIRT » (no subject)
(no subject) [message #707161] Mon, 01 August 2011 05:55 Go to next message
Hi All,
I am trying to generate a report in month wise,
But MONTH IS NOT IN PROPER ORDER IN CROSS TAB,
Its coming Alphabetical order by default,
How to order.
Plz help me on this,
Jeyinul.
Re: MONTH IS NOT IN PROPER ORDER IN CROSS TAB [message #707396 is a reply to message #707161] Mon, 01 August 2011 11:32 Go to previous messageGo to next message
I assume your month is not a date field. If it is a string, add a sort
expression to the crosstab with an expression similar to:
if( data["month"] == "Jan" ){
1;
}else if ( data["month"] == "Feb"){
2;
}else if ( data["month"] == "Mar"){
3;
Jason
On 8/1/2011 5:55 AM, jeyinul wrote:
> Hi All,
> How to order.
> Regards,
> Jeyinul.
Re: MONTH IS NOT IN PROPER ORDER IN CROSS TAB [message #707885 is a reply to message #707396] Tue, 02 August 2011 03:22 Go to previous messageGo to next message
Hi Jason,
Its not working.
I added in Binding.
Field name is lookupcode. It has month names
I added
if(dimension["Group3"]["LOOKUP_2_Data Set4::LOOKUPCODE"] == "Jan" ){
1;
But its not working.
Please help me on this,
Jeyinul.
Re: MONTH IS NOT IN PROPER ORDER IN CROSS TAB [message #708017 is a reply to message #707396] Tue, 02 August 2011 06:40 Go to previous messageGo to next message
Hi Jason,
Its a cross tab. Where i have to add the expression in cross tab.
Please give details and what time will come to online,.
Plz let me know.
Jeyinul.
Re: MONTH IS NOT IN PROPER ORDER IN CROSS TAB [message #708210 is a reply to message #707885] Tue, 02 August 2011 11:17 Go to previous messageGo to next message
You do not add a binding. Select the crosstab and in the properties
view click on the sorting tab and add it there. Take a look at the
attached example.
Jason
On 8/2/2011 3:22 AM, jeyinul wrote:
> Hi Jason,
> Its not working.
> I added in Binding.
> I added
> 1;
> Jeyinul.
Re: MONTH IS NOT IN PROPER ORDER IN CROSS TAB [message #708705 is a reply to message #707396] Wed, 03 August 2011 01:20 Go to previous messageGo to next message
This also not working.
Re: MONTH IS NOT IN PROPER ORDER IN CROSS TAB [message #708795 is a reply to message #708210] Wed, 03 August 2011 03:20 Go to previous messageGo to next message
I checked your attached file. Its not in proper order.
Output is,
Feb 42
Jan 32
Mar 52
Plz help
Re: MONTH IS NOT IN PROPER ORDER IN CROSS TAB [message #709163 is a reply to message #708795] Wed, 03 August 2011 11:15 Go to previous message
I am running this in 2.6.1 and it displays in the proper order.
I have added the running sum you asked for in the other thread and my
output looks like:
Jan 32
Feb 74
Mar 126
I have attached the report.
What version of BIRT are you using? I do not believe the sort will work
in 2.5.0 if that is what you are using. You will need to sort it on the
dataset instead of the crosstab.
Jason
> Output is,
> Feb 42
> Jan 32
> Mar 52
> Plz help
Previous Topic:Parameter that decides wich table show
Next Topic:Enabling study layout in JavaScript generated axes
Current Time: Thu Jul 24 22:22:04 EDT 2025
Powered by FUDForum. Page generated in 0.06484 seconds
