Home » Archived » BIRT » Using Table of Contents (TOC) causes entire Application to Shift
Using Table of Contents (TOC) causes entire Application to Shift [message #708382] Tue, 02 August 2011 14:10 Go to next message
I'm using the BIRT 2.6.1 WebViewer in an application. The WebViewer is
surfaced in an iframe. When a user clicks on an entry in the Table of
Contents on a report, the entire page is repositioned with everything
shifted left and up.
I've attached 2 screenshots that shows the before and after of clicking
on an entry in the Table of Contents.
Any help or advice would be appreciated
  • Attachment: after.png
    (Size: 68.70KB, Downloaded 275 times)
  • Attachment: before.png
    (Size: 68.55KB, Downloaded 280 times)
Re: Using Table of Contents (TOC) causes entire Application to Shift [message #708446 is a reply to message #708382] Tue, 02 August 2011 16:10 Go to previous messageGo to next message
This looks like the page containing the iframe is shifting. What does
the code look like?
Jason
On 8/2/2011 2:10 PM, Raishad Maharaj wrote:
> Thanks
Re: Using Table of Contents (TOC) causes entire Application to Shift [message #714526 is a reply to message #708446] Wed, 10 August 2011 13:31 Go to previous messageGo to next message
The full html is too big to attach, it's located here
http://dl.dropbox.com/u/104815/iframe.html
Overall, it's a pretty complicated framework
We're surfacing BIRT in an iframe
<IFRAME style="MARGIN: 2px; WIDTH: 100%; HEIGHT: 600px" id=$wjgp5v
class="epnyReadOnly epnyIFrame" onfocus="return
gEpnyTop.eFire(14,this,event)" tabIndex=1
src="http://usdadrmbase.infor.com:8280/scereports/frameset?__report=report/Item_List.rptdesign&amp;__showtitle=false&amp;p_DATABASE=SCPRD&amp;p_SCHEMA=WMWHSE1&amp;p_conn=SCPRD_wmwhse1&amp;p_CONN=BIC_REPORT&amp;p_uid=admin&amp;outputLocale=en&amp;p_locale=en&amp;__locale=en_US&amp;__offsetMin=0&amp;__timezone=America/Chicago&amp;_id=010D2CFA8B4F9901F827F1576EE7F2DB&amp;dbtype=MSS"
frameBorder=1 name=$wjgp5v eCSId="$wjgp5v" epnyValue=""></IFRAME>
We also use JFreeCharts for some charts, and we're able to have the user
click on the chart without causing this issue where the whole page shifts.
> the code look like?
> Jason
>> Hi,
>> Thanks
Re: Using Table of Contents (TOC) causes entire Application to Shift [message #714533 is a reply to message #714526] Wed, 10 August 2011 13:52 Go to previous messageGo to next message
Any chance you could try the viewer tag instead of the iFrame?
http://www.eclipse.org/birt/phoenix/deploy/viewerUsageMain.php#tags
Also if you could reproduce the issue with a standard html page so we
can test it, that would be good.
Jason
>> the code look like?
>> Jason
>>> Hi,
>>> Thanks
Re: Using Table of Contents (TOC) causes entire Application to Shift [message #1808279 is a reply to message #714533] Fri, 21 June 2019 00:56 Go to previous message
HI,
I would like to have TOC in my PDF report, can the TOC generated dynamically ?
Please do help as its urgent.
Thanks in Advance
Krishna
Previous Topic:Can BIRT write PDF metadata?
Next Topic:Table with Vertical Scroll Bar
Current Time: Fri Jul 25 06:58:49 EDT 2025
Powered by FUDForum. Page generated in 0.08908 seconds
