Home » Archived » BIRT » Embeddable report and CSS(Embeddable report is ignoring CSS classes)
Embeddable report and CSS [message #708048] Tue, 02 August 2011 07:35 Go to next message
I'm having an issue with the HTMLRenderOption.setEmbeddable option. I'm trying to embed a report in an existing web page and I'm using an external CSS style sheet in the report, the same CSS I'm using in the page.
When the setEmbeddable property is set to false the report generates an HTML output with the classes that are defined in the style sheet, something like '<div class="name">Entry 1</div>', but if I set the setEmbeddable property to true all the imported classes are removed from the generated HTML and the previous example becomes '<div>Entry 1</div>'.
Is this the normal behavior for BIRT? Shouldn't only the html and body tags be removed when I setEmbeddable to true?
I'm using BIRT 2.6 and the code I'm using is this:
ByteArrayOutputStream output = new ByteArrayOutputStream();
IHTMLRenderOption options = new HTMLRenderOption();
options.setOutputFormat(IHTMLRenderOption.OUTPUT_FORMAT_HTML);
options.setEmitterID(HTMLRenderOption.OUTPUT_EMITTERID_HTML);
options.setOutputStream(output);
options.setEmbeddable(true);
options.setBaseImageURL(getContext().getRequest().getContextPath() + "/images");
options.setImageDirectory(getContext().getServletContext().getRealPath("/images"));
options.setImageHandler(new HTMLServerImageHandler());
options.setMasterPageContent(false);
Re: Embeddable report and CSS [message #708255 is a reply to message #708048] Tue, 02 August 2011 11:56 Go to previous messageGo to next message
I just tried this in 3.7 and in 2.6.2 and both worked. What version are
you using 2.6.0 or 2.6.1.
Jason
> "/images");
Re: Embeddable report and CSS [message #708267 is a reply to message #708255] Tue, 02 August 2011 12:17 Go to previous messageGo to next message
I'm using version 2.6.2
Re: Embeddable report and CSS [message #708271 is a reply to message #708255] Tue, 02 August 2011 12:21 Go to previous messageGo to next message
Jason Weathersby wrote on Tue, 02 August 2011 11:56
Jason
Jason, thank you for your reply, could you please show me the sample code you've used?
Re: Embeddable report and CSS [message #708298 is a reply to message #708271] Tue, 02 August 2011 12:52 Go to previous messageGo to next message
Here is my code. Attached is the report and css file.
import java.util.logging.Level;
import org.eclipse.birt.core.framework.Platform;
import org.eclipse.birt.report.engine.api.EXCELRenderOption;
import org.eclipse.birt.report.engine.api.EngineConfig;
import org.eclipse.birt.report.engine.api.EngineConstants;
import org.eclipse.birt.report.engine.api.EngineException;
import org.eclipse.birt.report.engine.api.HTMLRenderOption;
import org.eclipse.birt.report.engine.api.IReportEngine;
import org.eclipse.birt.report.engine.api.IReportEngineFactory;
import org.eclipse.birt.report.engine.api.IReportRunnable;
import org.eclipse.birt.report.engine.api.IRunAndRenderTask;
import org.eclipse.birt.report.engine.api.PDFRenderOption;
public class RunAndRenderTask {
public void runReport() throws EngineException
IRunAndRenderTask task=null;
IReportEngine engine=null;
EngineConfig config = null;
try{
//System.setProperty("java.io.tmpdir", "c:/temp/test/testsampledb");
config = new EngineConfig( );
config.setLogConfig("c:/dwn", Level.INFO);
config.getAppContext().put(EngineConstants.APPCONTEXT_CLASSLOADER_KEY,
this.getClass().getClassLoader());
//config.getAppContext().put(EngineConstants.WEBAPP_CLASSPATH_KEY,
"C:\\work\\workspaces\\2.6.2workspaces\\BIRT
Metal\\APIs\\Reports\\eventjar.jar");
config.setBIRTHome("C:\\birt\\birt-runtime-2_6_2\\birt-runtime-2_6_2\\ReportEngine");
config.setLogConfig(null, Level.INFO);
Platform.startup( config );
IReportEngineFactory factory = (IReportEngineFactory) Platform
.createFactoryObject(
IReportEngineFactory.EXTENSION_REPORT_ENGINE_FACTORY );
engine = factory.createReportEngine( config );
IReportRunnable design = null;
//Open the report design
design = engine.openReportDesign("Reports/external.rptdesign");
task = engine.createRunAndRenderTask(design);
//task.setParameterValue("Top Count", (new Integer(5)));
//task.validateParameters();
options.setImageDirectory("./");
options.setOutputFileName("output/resample/external.html");
options.setOutputFormat("html");
//PDFRenderOption options = new PDFRenderOption();
//options.setOutputFileName("output/resample/fonttest.pdf");
//options.setSupportedImageFormats("PNG;GIF;JPG;BMP;SWF;SVG");
//options.setOutputFormat("pdf");
//EXCELRenderOption options = new EXCELRenderOption();
//options.setOutputFormat("xls");
//options.setOutputFileName("output/resample/customers.xls");
//options.setWrappingText(true);
task.setRenderOption(options);
task.run();
task.close();
engine.destroy();
}catch( Exception ex){
ex.printStackTrace();
Platform.shutdown( );
System.out.println("Finished");
* @param args
try
RunAndRenderTask ex = new RunAndRenderTask( );
ex.runReport();
System.exit(0);
catch ( Exception e )
e.printStackTrace();
Jason
>> are you using 2.6.0 or 2.6.1.
>> Jason
> code you've used?
Re: Embeddable report and CSS [message #708342 is a reply to message #708298] Tue, 02 August 2011 14:03 Go to previous message
Jason, thank's again for your reply, I can't seem to find the problem and the only big difference I can find is that I'm using the report in a web application using ActionBean's and JSP's on JBOSS 6.0
The output HTML generated by BIRT is being embedded into a JSP.
I'm attaching the test project I'm working on together with a sample output HTML I'm getting in the browser. I've removed the jar's from BIRT to save size.
Could you be kind enough to take a look at it if you have the time.
Thank you.
  • Attachment: output.zip
    (Size: 1.09MB, Downloaded 277 times)
[Updated on: Tue, 02 August 2011 14:08] by Moderator
Previous Topic:how to hide empty row
Next Topic:Multiple versions
Current Time: Sat Jul 26 12:50:43 EDT 2025
Powered by FUDForum. Page generated in 0.07778 seconds
