Home » Eclipse Projects » GEF » Bug in Draw2D Ellipse class
Bug in Draw2D Ellipse class [message #70247] Fri, 14 March 2003 01:28 Go to next message
Originally posted by: jayuen.alumni.uwaterloo.ca
Hi:
Based on some experimentation with our application, we have found a bug in
the org.eclipse.draw2d.Ellipse class in the containsPoint(int, int) method.
public boolean containsPoint(int x, int y) {
Rectangle r = getBounds();
int ux = x - r.x - r.width/2;
int uy = y - r.y - r.height/2;
return ((ux*ux) << 10 ) / (r.width*r.width)
+ ((uy*uy) << 10) / (r.height*r.height) <= 256;
The problem here is that when ux or uy are too large, the combination of
squaring either ux or uy and shifting by 10 bits overflows the integer and
the number becomes negative. An example of "too large" is 2000. This
causes the return value to be true which may not be the desired effect.
A fix for this is to declare ux and uy as longs rather than ints.
Jason
Re: Bug in Draw2D Ellipse class [message #70395 is a reply to message #70247] Fri, 14 March 2003 10:19 Go to previous messageGo to next message
http://dev.eclipse.org/bugs/show_bug.cgi?id=22701
We were assuming that ellipses would ever get so big. Oh well. We will fix
this.
"Jason Yuen" <jayuen@alumni.uwaterloo.ca> wrote in message
news:b4rsub$suk$1@rogue.oti.com...
> Hi:
method.
> Jason
Re: Bug in Draw2D Ellipse class [message #70451 is a reply to message #70395] Fri, 14 March 2003 10:51 Go to previous messageGo to next message
Actually, we came across the bug when we had a large FreeformLayer area in
our editor. If we mouse-clicked at a large enough distance away from an
elliptical figure, the algorithm in the Figure class for finding a figure at
the clicked mouse coordinates eventually hit the containsPoint method for
the Ellipse and failed (well, passed when it shouldn't have)
"Randy Hudson" <none@us.ibm.com> wrote in message
news:b4ss13$kn5$1@rogue.oti.com...
fix
> this.
> > Hi:
in
> method.
and
> > Jason
Re: Bug in Draw2D Ellipse class [message #70470 is a reply to message #70451] Fri, 14 March 2003 11:25 Go to previous messageGo to next message
Good point, we should do the bounding box test first, and if that fails, the
ellipse test wouldn't execute.
news:b4stt8$mlc$1@rogue.oti.com...
at
> fix
> > this.
> > > Hi:
bug
> in
> > method.
of
> and
effect.
> > > Jason
Re: Bug in Draw2D Ellipse class [message #70824 is a reply to message #70470] Sat, 15 March 2003 11:17 Go to previous message
Hm, If i remember correctly there must be
if (super.containsPoint(x, y))
By the way Randy you predicted a problem with overflow just a few days
before first user hit into it :) I think that long instead of int will be
sufficient.
Previous Topic:Use JTree as a figure in the GEF editor
Next Topic:Why i can't open the logic diagram?
Current Time: Thu Nov 13 02:48:15 EST 2025
Powered by FUDForum. Page generated in 0.07808 seconds
