Home » Modeling » GMF (Graphical Modeling Framework) » From Model to Edit Part
From Model to Edit Part [message #708199] Tue, 02 August 2011 11:05 Go to next message
Hi there,
I've been mulling it over for a long time.
I know how to get Model Element from Edit Part :
EObject myObject = myEditPart.resolveSemanticElement();
Is there a way to get the Edit Part from the Model Element please ?
Nicolas
Re: From Model to Edit Part [message #708209 is a reply to message #708199] Tue, 02 August 2011 11:17 Go to previous messageGo to next message
Hi nicolas,
have you tried
EditPart editPart = (EditPart) getDiagramGraphicalViewer().getEditPartRegistry().get(semanticElement);
Andreas
Re: From Model to Edit Part [message #708247 is a reply to message #708209] Tue, 02 August 2011 11:58 Go to previous messageGo to next message
Thanks for your answer Andreas.
getDiagramGraphicalWiever may be defined in IDiagramWorkbenchPart interface, implemented in <myModel>DiagramEditor. I don't really know how to access to this reference.
Here is my usecase :
I had just created my diagram and open my Diagram in my Diagram Editor :
Resource diagram = <myModel>DiagramEditorUtil.createDiagram(diagramModelFileURI, domainModelFileURI, monitor);
<myModel>DiagramEditorUtil.openDiagram(diagram);
1. <myModel>DiagramEditor is the one active Editor. Can I get a <myModel>DiagramEditor reference after that ?
2. Can I get <myModel>DiagramEditor reference without opening it ?
Thank you,
Nico
Re: From Model to Edit Part [message #708250 is a reply to message #708199] Tue, 02 August 2011 11:19 Go to previous messageGo to next message
Assuming that your "parentEditPart" contains the editPart which
represents the "targetModelElement" in one of its children or
grand-children, you can try the following line:
IGraphicalEditPart targetPart =
parentEditPart.findEditPart(parentEditPart, targetModelElement);
HTH,
http://mickaelistria.wordpress.com
http://twitter.com/#!/mickaelistria
http://www.petalslink.com
Re: From Model to Edit Part [message #708770 is a reply to message #708247] Wed, 03 August 2011 02:51 Go to previous messageGo to next message
Hi nicolas
The DiagramEditorUtil#openEditor returns a reference to your editor. Or you can
access the active editor like this:
IEditorPart myEditor = PlatformUI.getWorkbench().getActiveWorkbenchWindow().getActivePage().getActiveEditor();
This only works from within the display thread, so maybe you have to wrap this call into a Display#syncExec().
The IEditorPart is then adaptable to the graphical viewer:
IEditorPart myEditor = DiagramEditorUtil.openEditor(...);
GraphicalViewer viewer = (GraphicalViewer.class)myEditor.getAdapter(GraphicalViewer.class):
What is the need for that? Sure you can, but you can not access editparts since they will be created on editor open and disposed on editor close.
Re: From Model to Edit Part [message #708816 is a reply to message #708770] Wed, 03 August 2011 03:43 Go to previous messageGo to next message
Hi Mickael, Andreas
Thanks for your replies.
Good idea, I didn't think about getting my editor instance by that way.
It means that my solution does not solve my initial problem:
UC1:
I want to create my diagram, create a small initial model, and finally open my diagram. Sure I can use DiagramEditorUtil#createInitialModel to add model elements to my diagram, but I don't know how to define the position and the size of my elements on diagram.
UC2:
As a general rule, I wish I could add semantic element with it graphical aspect anywhere, in a view for example, even if the diagram is closed. For example, I generate <model>Diagram width GMF, So I two files, the model file xxx.model and the diagram file xxx.model_diag. I release a button in a view, and a new model element is added in xxx.model with it graphical aspect in xxx.model_diag, so I could see it when I opened my diagram.
For that, I found some code using CreateViewAndElementRequest class but in order to adding an object in the diagram, I had to get the rootEditPart.
Obviously, using editpart is not the way to do this...
HTH,
That might be my previous problem : I did'nt know how to get "(parent|root)EditPart"
Thanks for your help,
Nicolas
Re: From Model to Edit Part [message #708886 is a reply to message #708816] Wed, 03 August 2011 04:58 Go to previous messageGo to next message
Hi Nicolas,
UC1:
I did something similar in my open source project YAKINDU Statechart Tools. This code creates a semantic element (initialState) and adds some layout constraints to the view. Maybe this is a starting point for you.
//Create semantic element
Entry initialState = SGraphFactory.eINSTANCE.createEntry();
		initialState.setKind(EntryKind.INITIAL);
//Create view for semantic element
Node initialStateView = ViewService.createNode(
				parentView, initialState,
				SemanticHints.ENTRY, DiagramActivator.DIAGRAM_PREFERENCES_HINT);
//Set inital bounds for the view
Bounds bounds = NotationFactory.eINSTANCE.createBounds();
		bounds.setX(70);
		bounds.setY(20);
		initialStateView.setLayoutConstraint(bounds);
UC2:
Basically, the approach of UC1 works for that Usecase, too. You can simply load the resource and modify it like this.
Re: From Model to Edit Part [message #709727 is a reply to message #708886] Thu, 04 August 2011 04:27 Go to previous message
Hi Andreas,
Thanks for your example. I will go into detail soon.
Nicolas
Previous Topic:EMF and GEF
Next Topic:Variables View
Current Time: Thu Jul 24 16:44:42 EDT 2025
Powered by FUDForum. Page generated in 0.04003 seconds
