Home » Archived » BIRT » dinamical chart marker from dataset
dinamical chart marker from dataset [message #707434] Mon, 01 August 2011 12:39 Go to next message
I'd like to draw a chart with a dinamical marker (taken from a filed of
my dataset). Is it possible with birt. I am using 2.6.2 version.
Bye
Nicola
Re: dinamical chart marker from dataset [message #707453 is a reply to message #707434] Mon, 01 August 2011 13:23 Go to previous messageGo to next message
You can if the marker is a url. Currently markers do not support blobs.
Is the field a URL?
function beforeDrawSeries( series, seriesRenderer, context )
importPackage( Packages.org.eclipse.birt.chart.model.type );
importPackage( Packages.org.eclipse.birt.chart.model.type.impl );
importPackage( Packages.org.eclipse.birt.chart.model.attribute );
importPackage( Packages.org.eclipse.birt.chart.model.attribute.impl );
//Marker Types (MarkerType.java)
//BOX_LITERAL
//CIRCLE_LITERAL
//CROSS_LITERAL
//CROSSHAIR_LITERAL
//DIAMOND_LITERAL
//ELLIPSE_LITERAL
//FOUR_DIAMONDS_LITERAL
//HEXAGON_LITERAL
//TRIANGLE_LITERAL
//STAR_LITERAL
//SEMI_CIRCLE_LITERAL
if( series.getClass() == LineSeriesImpl ){
//series.getMarkers().get(0).setType( MarkerType.TRIANGLE_LITERAL);
series.getMarkers().get(0).setType( MarkerType.ICON_LITERAL);
series.getMarkers().get(0).setFill( ImageImpl.create(
"http://www.actuate.com/images/copy/thumb_businessintelligence.gif" ) );
Jason
On 8/1/2011 12:39 PM, nicola wrote:
> Bye
> Nicola
Re: dinamical chart marker from dataset [message #707983 is a reply to message #707453] Tue, 02 August 2011 05:46 Go to previous messageGo to next message
I intend a marker as a number.
in my chart I am going to draw a line chart, after selecting an exam as
input parameter.
When selecting, for example, exam AAA the marker is 5, for exam BBB the
marker is 8, ...
So I know the marker after selecting the input parameter.
Bye,
Nic
> Is the field a URL?
> //BOX_LITERAL
> //CIRCLE_LITERAL
> //CROSS_LITERAL
> //CROSSHAIR_LITERAL
> //DIAMOND_LITERAL
> //ELLIPSE_LITERAL
> //HEXAGON_LITERAL
> //TRIANGLE_LITERAL
> //STAR_LITERAL
> Jason
>> Hi,
>> Bye
>> Nicola
Re: dinamical chart marker from dataset [message #708190 is a reply to message #707983] Tue, 02 August 2011 10:44 Go to previous message
Currently markers do not support text but you could make an image that
contained the text and use an image marker. Take a look at the attached
report. It has two embedded images and depending on chart values one or
the other is selected.
Jason
> input parameter.
> marker is 8, ...
> Bye,
> Nic
>> Is the field a URL?
>> //BOX_LITERAL
>> //CIRCLE_LITERAL
>> //CROSS_LITERAL
>> //CROSSHAIR_LITERAL
>> //DIAMOND_LITERAL
>> //ELLIPSE_LITERAL
>> //HEXAGON_LITERAL
>> //TRIANGLE_LITERAL
>> //STAR_LITERAL
>> Jason
>>> Hi,
>>> Bye
>>> Nicola
Previous Topic:Small doubts about the meter
Next Topic:How to set the layout of the report
Current Time: Tue Jul 22 20:35:49 EDT 2025
Powered by FUDForum. Page generated in 0.07121 seconds
