Integrating the Report Engine to RCP plugin [message #705923] |
Sat, 30 July 2011 11:36  |
I cant get the TargetPlatform to work.
I added all required plugins from the rcp app iam programming a plugin for,
then i deleted all duplicate plugins from the report engine plugins and added the rest to the TargetPlatform via the Directory of the report engine plugins.
Now when unchecking all plugins from the Report Engine directory it starts fine, when starting with the Report Engine plugins in my TargetPlatform the appended error is thrown.
Even though the com.ibm.icu.util plugin is contained within the TargetPlatform since we already use it.
And i had to get the org.eclipse.datatools.modelbase.sql.query_1.1.1.v201008100700 from the 3.7 Birt since it was missing in the 2.6 distribution.
All Tutorials only say to add the dependencies but i cant get even the target platform to work.
Is there anything else i didnt consider when adding the Report Engine plugins to the Target Platform?.
Plz help iam new to this rcp/plugin stuff, its for a intership.
Another Obversation is when validating the plugins prior to run i have some errors with the batik und w3c bundles saying:
org.wc3.dom.svg
Missing Constraint: Require Bundle :org.wc3.dom.smil;bundle-version="0.0.0"
!ENTRY org.eclipse.osgi 4 0 2011-07-29 13:08:38.728
!MESSAGE Anwendungsfehler
!STACK 1
java.lang.NoClassDefFoundError: com/ibm/icu/util/ULocale
at org.eclipse.ui.internal.Workbench$7.run(
Workbench.java:665)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(
Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(
Workbench.java:663)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(
PlatformUI.java:149)
at com.ceyoniq.admin.core.internal.AdminApplication.start(
AdminApplication.java:39)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(
EclipseAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(
EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(
EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(
EclipseStarter.java:369)
EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke0(
Native Method)
at org.eclipse.equinox.launcher.Main.invokeFramework(
Main.java:619)
at org.eclipse.equinox.launcher.Main.basicRun(
Main.java:574)
at org.eclipse.equinox.launcher.Main.run(
Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(
Main.java:1383)
Caused by:
java.lang.ClassNotFoundException: com.ibm.icu.util.ULocale
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(
BundleLoader.java:460)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(
BundleLoader.java:422)
BundleLoader.java:410)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(
DefaultClassLoader.java:107)
... 18 more
Re: Integrating the Report Engine to RCP plugin [message #707832 is a reply to message #705923] |
Tue, 02 August 2011 01:38   |
I did get the org.eclipse.birt.examples.rcpengine to work.
But, as i said i cant even add the Birt Report Engine to the Target Platform,
since it seems to Conlflict with ouer plugins or so.
To Circumvent this i used the Report Engine 2.6.0, since all Plugins both, we and the report engine, used had the same version and deleted them in the report engine plugins directory. The com.ibm.icu Jar was one of them.
By now i also fixed the missing constraint message, so by now validating the plugins returns no errors.
When typing ss in the osgi console bevore the crash it return the com.ibm.icu as
active and the report engine plugins as lazy.
So to summarize, with the plugins in ouer Target Platform, the app Crashes on Startup with the above error, without it runs fine.
This is particular strange to me, since i already tried to integrate the Chart Engine with success.
Edit:
Another Update, the birt-rcp-report-designer-2_6_0 does work with ouer rcp application, without even deleting the double plugins :/.
[Updated on: Tue, 02 August 2011 02:54] by Moderator
Re: Integrating the Report Engine to RCP plugin [message #708384 is a reply to message #707832] |
Tue, 02 August 2011 14:13   |
Is there anyway you could send me a project that reproduces the issue?
Jason
> Platform,
> of them.
> com.ibm.icu as
FUDForum. Page generated in 0.17674 seconds
