Home » Archived » BIRT » How to set the layout of the report
How to set the layout of the report [message #706899] Sun, 31 July 2011 22:12 Go to next message
It seems a simple question, but i really don't know how to solve this, also i don't get much info from googling.
i'm new in Java an also for BIRT report.
i want to make report which the paper size is A4. i make a title in Header with center alignment.
but when i view in HTML or Viewer then the center alignment is not really center.
my question is how to make the report is really center follow the user resolution size of the user's monitor?
sorry, my English is bad.
Forgot to tell you, i can not set the width by percentage (%).
Thx Before
[Updated on: Sun, 31 July 2011 22:24] by Moderator
Re: How to set the layout of the report [message #707397 is a reply to message #706899] Mon, 01 August 2011 11:40 Go to previous messageGo to next message
It should be centering it based on the A4 width setting. Put a border
around the page (in master page) and it should be centered in the middle
of it. See attached example.
Jason
> really center.
> resolution size of the user's monitor? sorry, my English is bad.
> Thx Before
Re: How to set the layout of the report [message #707803 is a reply to message #707397] Tue, 02 August 2011 00:18 Go to previous messageGo to next message
Jason Weathersby wrote on Mon, 01 August 2011 11:40
Jason
> really center.
> Thx Before
it's not what i want. i want the border is center at our or user's monitor.
btw thx jason for ur reply
Re: How to set the layout of the report [message #708201 is a reply to message #707803] Tue, 02 August 2011 10:56 Go to previous message
I do not know of an easy way to do this as the code is running on the
server and will not know what the size of the monitor is. You may be
able to use a text element containing client side javascript to resize
elements after it is rendered.
Jason
>> middle of it. See attached example.
>> Jason
>> > really center.
>> > Thx Before
Previous Topic:dinamical chart marker from dataset
Next Topic:how to hide empty row
Current Time: Wed Jul 23 01:22:51 EDT 2025
Powered by FUDForum. Page generated in 0.04902 seconds
